- Go to Admin Console > Reports.
- In the Report Status tab, hover over the report with a status of either Pending or In Progress that you want to cancel, click the button, and then click Cancel.
- In the Cancel Report dialog box, click Yes.
Canceling Reports
Reports are generated serially in the order in which they are started. Some reports are large and some reports take a long time to generate, and sometimes you may have an urgent need to get a report that is waiting in the queue completed. When you are viewing the Report Status page, you can cancel any pending or in-progress reports to better manage your overall reporting queue, avoid latency, and get your critical reports faster.
Last modified on February 19, 2026
