Item actions
Item selection
Navigation
Other
Box Notes shortcuts
To open a list of available keyboard shortcuts in Box Notes:- On a Mac, press Command and /
- On Windows, press Control and /
Box Sign shortcuts
To prepare your Box Sign documents or templates as a sender, use the following keyboard shortcuts:| ⌘ / Ctrl + x | Cut selected fields. |
| ⌘ / Ctrl + c | Copy selected fields. |
| ⌘ / Ctrl + v | Paste selected fields. Carries over copied field values. Pasted fields have a slight overlap in the same location as the original. |
| ⌘ / Ctrl + d | Duplicate selected fields. Combination of Copy and Paste. |
| ⌘ / Ctrl + Shift + d | Duplicate selected fields on all pages of all documents in the request, in the same position. See Duplicating fields on all pages. |
| ⌘ / Ctrl + left-click | Select multiple fields. After selecting, you can use these shortcuts:
Bulk reassign recipients within a signature request. Select two or more fields, then left-click to reassign the recipients. Additionally, you can delete the selected fields. |
| ⌘ / Ctrl + z | Undo* |
⌘ / Ctrl + y ⌘ / Ctrl + Shift + z | Redo* |
Esc | Cancel operation:
| Del | Delete the selected fields. |
- Adding, removing, moving, and resizing fields.
- Updating fields and their settings (including fonts), title and settings, recipient assignment, and Required/Not Required selection.
Box Drive shortcuts
To search your entire Box account with Box Drive, use the following keyboard shortcuts:- Mac: Ctrl + Option + Cmd + Space
- Windows: Ctrl + Alt + Shift + b
