Restricting Tags
Box enables tag creation by default. Your Box admin can restrict tag creation. If you’re a Box admin, to access tag settings, in the Admin Console go to Enterprise Settings > Content & Sharing > Content Creation.
Tagging Items in Box
To tag an item:-
Hover over the item you want to tag, then click the ellipsis (…) to open the More Options menu.
- Alternatively, you can right-click the item, and from the menu that displays select More Actions. Then click Add or Edit Tags.
- In the dialog box that displays, enter the tags you want to add to this item. You can add multiple tags, separated by a comma. Then click Save.
You must have folder permission level of “Editor” or higher to create tags for a folder.
Searching and Filtering with Tags
To search for all files with a specific tag, click the tag below a file’s name:
You can start typing a tag in the search view, and Box autofills possible tags. However, it does this only for content you own. It does not autofill tags that belong to content you do not own or content on which you collaborate.
