Using AutoFiler in Box Apps
AutoFiler allows you to add Metadata to your files during the upload process.
When your files are uploading, you can add Metadata to them in the Current File tab. Select the Metadata Template from the drop-down list.
Other required fields depend on the metadata template your Box Admin created.
Click Apply to All - a Confirm Apply To All dialog appears with the following text:
Applying these changes will apply the entered Metadata values to all remaining files.
Click Apply to All again. You can also Cancel this action.
