Create or delete a Hub in your enterprise and configure restrictions for your Hub. Table of contents
  1. Creating new Hub
  2. Logo and background image
  3. Co-owner settings on a Hub level
  4. Embedding a Hub
  5. Deleting a Hub
Creating new Hub
To create a Hub:
  1. Do one of the following:
    • In the sidebar, click the plus icon next to Hubs. The Hub creation page opens in a new tab.
    • In the Hubs gallery, click the New Hub button. If this is your first Hub, you see a You don’t have any Hubs yet message with a step-by-step tutorial. Click Get Started.
  2. Fill in the Hub name and description.
  3. Add any files that you want. Refer to Adding Content to Box Hubs for more information.
  4. Save your changes.
Restrictions
  • If you don’t specify a Hub name, it is auto-populated with Untitled Hub [date and time].
  • If you don’t add any description, it is not auto-populated and is not visible on the published Hub.
  • A Hub description can only have 2000 characters.
  • You can only add files or folders owned by your enterprise to your Hub.
You can change both the name and description in the edit mode.
You can add a logo and background images when you create your Hub, or later in the edit mode. You can center-align the logo. Doing so also center-aligns the hub name and description. For details, see Working with the Box Hubs Builder. To add a logo or background image, click the pencil icon on the logo or background. Then select an image from the gallery or upload it from Box or from your device. To delete a custom image, you need to first change the custom logo or background to another one. Then you need to click the pencil icon to open the gallery. Find your image in the gallery and click the X button on it. A pop-up message appears, asking you to confirm the image deletion.
If you delete the custom image, you won’t be able to restore it, but you can add it again from Box or from your device.
For the logo, we recommend using a square image. For the background, we recommend choosing images with a 5:1 aspect ratio and minimum width of 1600 px.
Only images in jpg or png format and smaller than 5 MB are accepted.
As a co-owner you can edit the Hub settings both in the edit and view mode. To do so:
  1. Open the desired Hub.
  2. Click the ellipsis to open the More Options menu.
  3. Click Hub Settings.
Your Hubs admin can change the default Hubs options for your enterprise. Depending on that, some of the below options can be greyed out. Contact your Hubs admin for more information.
The following options are available:
  • Restrict collaboration to within your enterprise: on by default when you first log in to Box. To allow adding external collaborators, turn this option off.
  • Control who can copy this Hub:
    • No one: the Make a Copy option is hidden for all users.
    • Only users within [your enterprise]: only internal users can copy. External users, including those with a shared link, cannot see the copy option.
    • Anyone (default): all users with access, including external collaborators and shared link users, can copy.
  • Control who can add or modify the collaborators:
    • Editors and co-owners (on by default when you first log in to Box)
    • Only co-owners
  • Control who can create or modify shared links:
    • Only co-owners
  • Manage Box AI features for this Hub.
These default settings only apply to Box accounts created as of November 4, 2025. Existing accounts retain their previous settings.
You can’t enable shared links in Hub settings if:
  • You’re an admin and you disabled shared links in the admin console for your enterprise.
  • You’re a Hub editor, but the Hub co-owner didn’t give you permissions to do that.
Permissions should be set to Invited People Only, and you can configure the other settings.
Embedding a Hub
Only Hub editors and co-owners can create an embedded widget for a Hub. Viewers cannot create shared links or embeds for Hubs they have access to. To embed a Hub anywhere on your webpage or system:
  1. Open the Hub you want to embed.
  3. Click Embed Hub.
  4. Select the size of the widget. Available options are:
    1. Small (330 x 400),
    2. Medium (500 x 400),
    3. Large (800 x 550),
    4. Custom.
  5. Copy the link and add it in the desired place.
Check the Hide Hubs Gallery option to prevent users from going to the Hubs Gallery in the widget.
To see the contents of the embedded Hub, you need to be invited to it or have access through the shared link. You must be a Hub editor or co-owner to create the embed or the shared link for the Hub.
Deleting a Hub
To delete a Hub:
  1. Select the specific Hub from the Hub gallery.
  2. Click the More options menu.
  3. Select Delete Hub.
A pop-up message with the following information appears: Are you sure you want to delete this Hub? The Hub will be deleted and users will lose access to some or all files in this Hub. Confirm the Hub deletion by ticking the I acknowledge this action cannot be undone checkmark in the pop-up message.
You must be a Hub Co-Owner to delete a Hub. When you delete it, the source content from Box is not deleted.
Last modified on July 8, 2026
