Known Issues
As of now, you can only invite users who have a Box account (any plan) to collaborate on a Hub.
User and enterprise migrations
Migrations have a negative impact on all Hubs created in the enterprise:
  • When a user migrates their content, the files and/or folders in a Hub become unavailable.
  • Enterprise migrations make all Hubs unavailable.
Limitations
  • Shield’s Information Barriers are not supported in Hubs.
  • Version history is not available.
  • There is no current file or folder limit for a Hub. However, Box Hubs is meant to have curated content, not to serve as a location for root folders.
  • Hubs does not support an editable shared link to a Hub.
  • Instant Login (admin only feature) doesn’t work with externally collaborated hubs. An admin can’t use instant login for a user in their enterprise and view content owned in another enterprise’s hub.
  • As of now, you can only add external collaborators using their main email address. Using an email alias results in an error We were unable to add [xyz] as a collaborator.
  • Hub collaborations are not shown in the External Users tab in the Users & Groups section of Admin Console.
  • Box Hubs is not fully interoperable with all features within Box, such as Box Shield and Box Governance. This limitation may affect your ability to meet compliance requirements that depend on these services.
  • As of now, images and text included as a block within a Hub have different data handling measures than files and folders.
Box Hubs Limits
Restrictions for Box Hubs:
  • Number of Hubs for each tenant - no limits.
  • Number of Hubs for each Hub owner - no limits.
  • Number of collaborators for each Hub - existing Box limits apply for number of collaborations for each item.
  • Number of collaborations for each Hub - limited to 500. Group collaboration counts as 1, the group members are not counted.
  • Number of members for each group that can be added to or deleted from Hubs’ collaborators list - existing Box limits apply.
  • Number of columns in a layout - up to 3. In the Box mobile app, layouts display as a single column.
  • Number of paragraph sections in a Hub - no limit. <90 sections in a single Hub allows for an optimal viewing performance.
  • Number of files for Box AI for Hubs in a Hub - 20,000.
    • When the limit is reached, Box AI for Hubs responds with the following error message: You have exceeded the limit of 20,000 items for this Hub. Box AI is now disabled. To reenable Box AI, remove enough items to get below this limit.
  • Number of files for Box AI for Hubs across all the Hubs in an enterprise - 10,000,000.
When either of the limits for Box AI for Hubs are reached, the AI service responds with an error message.
Only the first 4 MB of a document is indexed by AI.
Last modified on October 14, 2026
