Box Hubs are an easy to use content portal that allows you to curate, organize, view, and share content both internally and externally. With Box Hubs, you can:Documentation Index
Fetch the complete documentation index at: https://docs.box.com/llms.txt
Use this file to discover all available pages before exploring further.
- Bring your content together in a single, easily configurable site (no coding or admin rights needed)
- Add any content stored in Box to a hub, including individual files and folders
- Share Box Hubs with both internal and external collaborators
- Track engagement, usage, and performance of your content on a hub and file-level with built-in insights
- Ask questions across multiple, curated documents using Box AI and get instant answers
Note:
Box Hubs is available to Enterprise plans and above. Box AI for Hubs is available to Enterprise Plus and Enterprise Advanced plans.
Note:
You can only add files or folders owned by your enterprise to your hub.
Use cases
Use Box Hubs to create team, department, or organization-wide content sites. For example:- An employee onboarding resource page
- Project knowledge base
- Team site with contact lists, organization charts, meeting recordings
- Company asset library
- Sales enablement sites
- Workspaces - A secure home base for projects and teamwork with all the resources and insights users need to get the work done
- Content playlists - Published “content playlists” with curated items that users can skim or scroll through, often similar file types needed for a specific project or use case
- Content libraries - Libraries can house multiple types of documents for a broad subject matter. Users can use filters to find the content
Info
You can set the Box Hubs gallery as your Box start page. To do so, click your profile picture and go to Account Settings > Account > General Options. Choose Hubs from the dropdown list in Home Page.
