In the edit mode, click the Select Metadata to add filters that allow your users to search for content faster.
Hubs gallery
To search for a specific Hub, go to the Hubs gallery and enter the Hub name in the search bar. You can also filter and sort the Hubs.Filter options:
- All
- View Access
- Edit Access
Sort options:
- Recently updated
- Most viewed
Search indexes only the first 200 characters of a Hub description. This is the same text that appears on the Hub card in the Hubs gallery. Content beyond the first 200 characters isn’t indexed and won’t appear in search results.
Inside a Hub
Open the Hub and enter a keyword in the Hub search bar. You can also click the Filters icon in the search bar and use filters to make your search results more specific. You can filter the content by:- File Type (multi-choice)
- Document
- Presentation
- Spreadsheet
- Image
- Video
- Audio
- Drawing
- 3D
- Box Note
- Box Canvas
- Date Updated (multi-choice)
- Any time
- Last day
- Last week
- Last month
- Last year
- Custom range (you need to specify the date range)
- Owners (type in the name of the owner)
- Metadata
You can also use the global search, the Hub files are included in the search results.
