Box Relay is a flexible and powerful way to automate routine and repeatable business processes that are centered around content. In Relay, you define those processes by creating workflows. Those workflows consist of two parts: triggers and outcomes. Triggers are events that initiate Relay workflows. Outcomes are the results that occur from completing Relay workflows. Box provides a robust set of pre-built workflow templates, appropriate for a range of business lines and with pre-defined triggers and outcomes, that you can modify as you see fit. You may wish to try using a template to more quickly familiarize yourself with workflow components and to get started with Relay right away.
When you’re comfortable creating workflows, you may also wish to begin sharing your workflows as customized templates for others throughout your organization to use.
You can only create workflows that involve folders you own, co-own, or edit.
This topic explains the triggers and outcomes available in Relay workflows.
Relay Triggers
There are several types of triggers that you can choose to begin a workflow in Relay:
  • File events: actions that happen to a file within a parent folder, such as a file move or download.
  • Folder events: actions that happen to a folder within a parent folder, such as a folder move or share.
  • Form Submission: Relay starts a workflow when someone submits a form.
  • Files with metadata: actions that happen to a file with specified metadata attribute.
  • Task events: actions that happen to a file or folder within a parent folder as part of a workflow, such as a task being completed, approved, or rejected.
  • Manual start events: a workflow started on a file or folder by a user.
  • File Request events: requests made for a file.
  • Scheduled events: a specified date.
  • Sign events: actions that happen to an electronic signature in a file, such as complete, cancelled, expired, or declined.
The options you can configure for a Relay trigger depend on which trigger you choose.
File event options
Here, you are starting the workflow by selecting the file event.
relay-trigger-file-event-png
Then you choose the type of file event. For example, this workflow may begin when a file is uploaded, copied, or moved. It may begin when a file is locked or unlocked. It may begin when a watermark is added, or when a security classification is applied.
relay-trigger-file-event-options-png
Your next choice is to specify where this event is to take place — that is, in which folder the file resides or to which it will be moved or copied. To do this, click the Select a folder box and follow the prompts to specify the folder you want.
relay-selectfolderforevent-70014-png
(If you select Classification Applied as your event, before you select a folder Relay prompts you to select the type of classification to apply. More on classification labels in Box.)
  • If the selected folder has a classification label, the label will be displayed next to the folder name.
classificationlabelrestrictionsinfo-png
  • If any classification-based security policies apply to the folder, a short description will inform you about the restrictions. Click the icon next to the description to view the policy details.
classificationlabelrestrictionspopup-png
Folder event options
Here, you are starting the workflow by specifying the type of event that happens to or with a folder.
relay-trigger-folder-event-png
Then you choose the folder event. For example, this workflow may begin when a new folder is created, or when an existing folder is copied, moved, or deleted, or when a collaborator is added.
relay-trigger-folder-event-options-png
And as with a file event, you must specify where this event is to take place — that is, the folder in which this triggered folder resides, or to which it will be moved or copied. To do this, click the Select a folder box and follow the prompts to specify the folder you want.
Form Submission
With the Form Submission trigger, a Relay workflow starts whenever someone submits a response with Box Forms. You can choose which form triggers a workflow. When using the Form Submission trigger, Relay enables you to:
    • Use responses in forms as dynamic variables to name or rename content, map to Doc Gen tags in the Generate Document outcome to dynamically generate documents, and specify signers in a Box Sign signature request when using the Request a Signature outcome.
    • Use files attached to form submissions in file outcomes.
    • Use a form attachment’s destination folder in folder outcomes.
    • Carry over Metadata from form responses to a selected file or folder in an Add Metadata outcome.
File with metadata options
Here, you are starting the workflow when a metadata template you specify is applied to a file.
relay-trigger-file-with-metadata-event-png
Then you choose which metadata template.
relay-trigger-file-with-metadata-event-options-png
If you do not enable metadata in your organization, Relay cannot complete any workflows that employ metadata in any way. Typically metadata is enabled in most organizations. If you aren’t certain whether metadata is enabled, contact your Box Administrator.
You can also add one or more pairs of metadata attributes and values to further filter the content that initiates the workflow. In that way you can be highly granular with the type of file around which you want to build your workflow — for example, a contract from a specific vendor that exceeds a specific budget amount. To do this, after you select the metadata template, click Add a condition. The Select an attribute menu displays. Click the Select an attribute down arrow to display a drop-down list of all the possible metadata values you can specify.
relay-trigger-file-with-metadata-event-option-attributes-png
In the below example, you’re limiting the workflow to files with the Background Check Alert metadata template applied and whose start date is July 21.
relay-trigger-file-with-metadata-event-option-attributes-background-check-png
As with file and folder events, your next choice is to specify in which folder this event is to take place. To do this, click the Select a folder box and follow the prompts to specify the folder you want.
Task event options
Here, you are starting or continuing the workflow with a task event.
relay-trigger-task-event-png
And then you select when the assignee has completed a general task.
relay-trigger-task-event-general-png
… or has approved or rejected an approval task.
relay-trigger-task-event-approval-png
Manual start options
Here, the workflow does not kick off automatically, with no intervention on your part.  Instead, you partially pre-configure a workflow, directly from a document or set of documents that already exist in a Box folder.  Another individual — the workflow starter — selects one or more files, completes the incomplete steps of the workflow (such as designating task assignees), and only then manually initiates the workflow.
relay-trigger-manual-start-event-png
A manual workflow is especially useful when task assignees vary — for example, when a contract must be reviewed by different sets of corporate executives who are assigned by different department heads.  More details on manual start workflows.
File Request options
File Request is a separate feature, available to every paid Box Business Plan account (or higher).  Basically, File Request enables you to create a Web form in seconds that anyone can use to upload content to Box. When you specify File Request as a workflow trigger, the workflow launches automatically each time someone completes your File Request form and uses it to submit content to the Box folder you’ve designated.
relay-trigger-file-request-event-png
This is especially useful when gathering content from someone is the first step in a workflow.  For example, Finance teams can use File Request to solicit vendor invoices and have Relay route those invoices through an approval process.  More details on using a File Request to kick off a workflow.
Scheduled event options
Here you can create a Relay workflow and schedule it to begin at a later date, and at regular occurrences (daily, weekly, monthly, and so on) so you only need to activate it once. Among the reasons you may wish to do this:
  • Month-end close process – review and approval of financial statements at the end of each month to close the books
  • R&D capitalization check – engineering confirmation that quarterly resource allocations are correct for capitalization purposes
  • Business review – department leads update quarterly objectives in a shared PowerPoint deck
  • Compliance check – once a year employees across an organization confirm they’ve read the employee handbook
relay-trigger-scheduled-event-event-png
Your next choice is to specify a start date, a repeat frequency (daily, one or more times a week, monthly, annually), and an end date (at a designated time, after a certain number of occurrences, or never, if there is no end date).  Click each box to display a drop-down menu from which you can then click your desired options.
relay-trigger-scheduled-event-event-options-png
Sign event options
Relay allows you to define workflows based on the results of electronic signature events in Box Sign. Here, you are starting the workflow by selecting a Sign event.
relay-trigger-sign-event-png
Your next choice is to select a Sign event for the workflow, and then select which folder those Sign events will occur in.
relay-trigger-sign-event-options-png
Outcome actions
The next step, regardless of what trigger you have chosen, is to specify an outcome. The choices in selecting an outcome vary. Any data used as variables in Relay to feed into workflow outcomes is treated as metadata.
  • With file events the process of specifying an outcome is essentially the same as selecting a trigger.
    • If the selected file has a classification label, the label will be displayed next to the file name.
classificationlabelfilerestriction-png
    • If any classification-based security policies apply to the file, a short description will inform you about the restrictions. Click the icon next to the description to view the policy details.
    • If the selected file is a Box Sign signature request file, you can choose to select the file with or without the signing log.
filerequestsigninglog-png
  • With folder events the process of specifying an outcome is also essentially the same as that of selecting a trigger, with one exception:
    • If you select Apply Classification as the folder outcome, you then must also click the Select a classification drop-down arrow and click the security classification you want (collaborators only, company employees only, short-term sharing, and so on).
    • Optionally, if you want the classification policy you select to take precedence over all other security classifications that may be in place on that folder’s files and subfolders, check Overwrite all existing classifications with this value.
relay-outcome-apply-classification-png
If you select a folder name that already exists, you can choose to use the existing folder instead of creating a new folder. Select Use existing folder when present to avoid creating a new folder.
naming-exisiting-folders-png
If you decide to not use the existing folder and leave the checkbox unmarked, the workflow creates a new folder with a timestamp added at the end of the folder name.
Dynamic Naming
If you select copy, rename, or create (folders only) as the file/folder outcome, you can use dynamic variables to create folder or file names. These variables dynamically reference certain attributes without the need to hardcode the names within workflow.
trigger-dynamic-variables-png
  • Available variables include:
    • current date
      • Example formats include: Month “DD” “YYYY”, “MM” “DD” “YYYY”, Month “YYYY”
    • Metadata attributes from file requests, and workflow folder,
      • Current outcome folders and files for Enterprise users.
    • file/folder names used within a trigger or current workflow outcome
    • Name of the folder that triggered the workflow
      • This variable references the folder modified in the trigger
  • You can include both static and dynamic text when renaming, copying, or creating a folder or file.
*Metadata attributes from current outcome file or folders available for Enterprise plans and above.
Metadata outcome options
The process for creating metadata and task outcomes differs from creating metadata and task events. These are explained below. As a result of a trigger event, you can:
  • specify the file or folder to which you want to apply a metadata template, then specify the metadata template you want to apply.
  • add or update metadata attributes in that template
Here’s an example:
  • You apply a “press release” metadata template to a newly-created press release.
    • One of the attributes in this template is “Status.”
  • You create a workflow such that, as the press release is developed, its status changes with each step, from “in progress” to “in review” to “approved.”
Admin PermissionsYou can specify and apply multiple attributes within the same template, but you cannot apply an attribute across multiple templates. To apply metadata values across multiple templates, you must create a separate outcome for each template.
To apply a metadata template as an outcome and specify an attribute to change:
  1. Under What is the next action? click Add Metadata.
  2. Under What file or folder do you want to apply metadata to? click the down arrow and select the file.
    • This adds the template to the file or folder you’ve just specified.
  3. Under What metadata would you like to apply? click anywhere in the box to display a list of the metadata templates.
  4. Click the template you want.
  5. To add a new metadata attribute-value pair, click Add a Value. Then click Select an attribute.
    • From the list of attributes that displays, locate the attribute you want to update, and then click the down arrow next to it to select a value.
If you’re adding metadata to a folder, ensure the admin has enabled Cascading Folder Level Metadata for the user. Enabling this setting will not cascade Relay-applied metadata to the folders.
cascading-folder-level-metadata-png
Repeat the above steps and add discrete metadata outcomes to change the metadata attribute value to appropriately reflect the status of the workflow. For example, in the press release workflow, select the Status attribute and add a discrete value for in review when the release forwards to a reviewer, and when the release is ready to be published create an outcome with a status attribute of approved. Get more information on creating a metadata structure for your enterprise.
Dynamic Naming with outcomes
When using metadata templates to build folder or file outcomes, you can use dynamic naming to reference the attributes you select. However, if you select a template that contains attributes your selected file or folder does not have, the missing attributes are indicated as missing in the following format upon execution of the workflow: “(missing){attribute title}”
Using metadata attributes with current file or folder outcomes requires an Enterprise or above plan. See Relay Features in Box Business Plans – Box Support for more information on available Relay for Enterprise accounts.
Task outcome options
As the result of a trigger event, you can assign a task. For example, when a vendor uploads a contract proposal to the folder you specify, you can configure Relay to assign a task on that file to a specific individual for review or approval. You can also re-route the workflow if someone rejects the task they’ve been assigned. Regardless, when a task is approved or completed, Relay automatically moves the workflow forward. Any one of the four triggers can result in a task outcome. To create a task outcome
  1. In the Outcome box, click Assign a Task.
relay-outcome-assign-task-png
  1. Decide what type of task this is. If you want the assignee merely to accept or reject the task — for example, approving or rejecting a budget — under What type of task would you like to assign? click Approval Task. For any other activities — for example, copy editing a blog or filling out an invoice — click General Task.
  2. Under What are the task details? click the Assignee(s) box and begin typing the name or email address of the assignee. Relay displays a list of possible assignees. Click the assignee you want.
    • You can assign a task to the person who first initiated this workflow. This person displays in the list of possible assignees as the Workflow Starter. This is useful when you create a workflow that could be initiated by any number of people — for example, when any one person from a group of loan underwriters submits a loan application for review and approval. (In one specific circumstance the workflow starter may not be the person who initiates the workflow. For details, see the note at the bottom of this article.)
    • You can assign a task to multiple individuals.
    • If you do assign a task to multiple individuals, every assignee must complete the task before Relay advances the workflow. If instead you want the workflow to move forward when just one assignee completes the task, check Only one assignee is required to complete this task.
  3. In the Message box, enter a specific description of the task.
  4. Optionally, enter the number of days or hours you want to allow the individual to complete this task.
  5. In the Assign the task to a file box, specify on which file the task is to be assigned.
relay-outcome-assign-task-general-png
If a task assignee rejects the task, by default Relay ends the workflow. You have three options:
  1. Do nothing and preserve the End the flow default.
  2. Send Relay back to an earlier task outcome, essentially rerunning the workflow from that point forward.
  3. Assign a general task.
    • You can assign this general task to the workflow starter, if you wish.
To send Relay back to an earlier task outcome
  • Click Go to Outcome [outcome step #].
    • You must select a previous task outcome (either general or approval). For example, if someone rejects a task you cannot select a file copy or metadata update action.
    • You cannot select a task outcome later in the workflow.
To assign a general task
  1. Click Assign a general task.
    • This can help you establish a review cycle. For example, if the vice president rejects a contract, you can route the contract back to the original sales rep. The sales rep can modify the terms of the contract accordingly and the workflow eventually makes its way back to the VP for approval.
    • You can only assign a general task — not an approval task.
  2. Choose what happens after this general task completes. Either:
    • continue the process from a previous task outcome; or
    • continue the process from the task outcome for which you’ve configured the rejection route.
As with other events, Relay logs and tracks rejected tasks. It tracks steps that have been repeated due to a rejection as separate successive events.
Notification outcomes
Use notification outcomes to apprise stakeholders of key developments in workflow progress — for example, when a process has ended or a file has been rejected.  Relay sends an automatic message to the people you designate, via the Box Web app and email.  If you’re the workflow creator, you can customize the message Box sends, to ensure clarity or suggest another action for the message recipients. More on rejection routing More on creating a new workflow More on file and folder security classification More on watermarking More on using Box File Request
  • If you have multiple outcomes and multiple tasks assigned, the list of workflow steps may become a little harder to track. Use the collapsible workflow summary view, in the lefthand navigation, for a quick but comprehensive visual overview of the workflow you’re creating.
  • When a rejected task prompts Relay to rerun some workflow steps, any file copy actions it repeats could result in orphaned files and affect your version control. For that reason, consider moving files, rather than copying them.
Document generation and signature outcomes
To dynamically generate documents, select Generate Document as an outcome. From here, you can use dynamic variables, including Box Forms submissions (if the trigger was Form Submission), manual data entry, and more, to generate documents. Once the document is generated, you can send it for e-signature or approval using the Request Signature outcome in subsequent outcomes. In order to successfully send documents for signature using the Request Signature outcome, ensure that you have created and included Box Sign template tags within your Doc Gen template in Microsoft Word manually or by inputting the tags by using the Box Doc Gen Template Creator add-in. Step 1. Configuring Document Generation as an Outcome to the workflow
  1. Under Outcome, select Generate document.
  2. Choose a Doc Gen template to configure.
  3. Map the Doc Gen tags from the template with static values or dynamic variables.
  4. Select the destination folder where Relay will save the generated document.
  5. Select file format
    1. PDF
    2. Docx
      1. Not available for automated signature requests via Relay
relay-doc-gen-png
relay-doc-gen-folder-png
The document you generate through a Relay outcome becomes available in all subsequent:
  • File outcomes
  • Metadata outcomes
  • Task assignment outcomes
  • Signature request outcomes, enabling you to automatically send the generated document for signature or approval with Box Sign if the Request Signature outcome is configured as one of the subsequent outcomes.
    • Signature request file and signing log become available after initial outcome
Step 2. Sending the generated document for e-signature or approval with Box Sign
relay-sign-outcome-png
  1. Select the Request Signature outcome.
The Request Signature outcome can only be utilized in combination with the Generate Document outcome configured in previous outcomes.
  1. Select the file generated by the previous outcome.
  2. Under Add Recipients, you can add signers, approvers, or Get a Copy recipients by either leveraging dynamic variables or by manually inputting an email address. For example, if you added an email address field within your Box Form, you can dynamically leverage the email address entered within that field to send the generated document for signature or approval.
  3. For each recipient, specify one of the following Box Sign recipient roles: Signer, Approver, or Get a Copy. To learn more about Box Sign recipient roles see this article.
  4. (Optional) For multiple recipients, specify the signing order by enabling Specify Signing Order and adding the number next to each signer’s name that corresponds to the desired signing order. For example, #1 will correspond to the first signer in the workflow, #2 the second signer, and so on.
Ensure you do not use the same email twice (for example, by using a dynamic variable and an email input) as this will cause the workflow to fail.
  1. (Optional) Update metadata on the signed files to include real-time signature request status updates during the signature request process. To do this:
    1. Click Select a metadata template for tracking signature requests (optional).
    2. Specify the metadata template and the metadata attribute that Relay will populate with signature request status. Signature request status values include: In progress, Signed, Cancelled, and Expired.
  2. Click Activate.
For additional information on using Box Doc Gen in Relay, see Generating Documents with Doc Gen and Relay.
Last modified on October 12, 2026
