Preview displays most documents without issue, but we cannot guarantee perfect accuracy. If your file doesn’t display properly in preview, use the file’s native application to open it.
Video file preview
Video preview is available only to Business level Box accounts, and above. Free or personal users can preview video files owned by these accounts. When you preview video files, you can use keyboard shortcuts to perform basic actions. Preview also supports closed captioning in videos, and for accessibility it works with screen reader programs such as Mac’s VoiceOver. Video preview without Box login using Public shared link is only limited up to 1 hour. Both 480p and 1080p previews are supported. When you preview a video, you can use the settings gear to adjust the resolution. Only Business Plus accounts, or higher, can modify the quality of the previewed video.Previewing files
To preview an item, click the item’s name. It opens directly within the Box interface. When an individual follows a shared link to a file, by default the file previews within the Box interface, rather than downloading or displaying within the native application. This is a typical Box Preview screen:
- File name and parent folder. View the name of the file you are previewing, the name of that file’s parent folder and the time of last update. Click the name of the parent folder to navigate back to it. If there’s a shared link icon (), you can click it, and Box automatically copies the link to your clipboard so you can quickly share the file with others. Select the version badge to see the file’s version history, including version number, uploader, upload date, and upload size.
- Primary file actions. From here you can do the following (note that some actions may be limited based on your permission level):
- View avatars of the people who have recently edited, commented on, or viewed the file
- Select the ellipsis (…) to access a menu from which you can select a wide range of actions, such as moving it, renaming it, locking it, downloading a PDF version of it, and more.
- Access Box AI. Box AI in Preview is available for Business, Business Plus, Enterprise, Enterprise Plus, and Enterprise Advanced accounts.
- Query the document with Box AI
- Open the file
- Download the file
- Create a shared link to the file
- Open the Share window to invite someone to collaborate on the file
- Information about the file. Here you can:
- Select the bubble icon () in the side navigation to open or close the Activity panel. In this panel, you can view version history, file comments, view and assign tasks, and write comments associated with the file.
- Select the details icon () in the side navigation to open or close the Details panel. In this panel, you can view or add a wide range of information about the file, including classification, file access statistics, and basic file properties (dates created and modified, size, owner, uploader, and so on).
- Select the metadata icon () in the side navigation to open or close the Metadata panel. In this panel, you can view or add a range of metadata attributes associated with this file.
- More information on metadata in Box.
- A list of recommended apps. Icons in this sidebar give you one-click access to the applications you most commonly use with Box. In this way, you can quickly share the file you’re previewing with Slack, send it to DocuSign, and so on. The applications that display in your recommended apps bar vary, depending on how you most commonly work in Box. More information on recommended apps.
Known limitations:
- While Box enables you to preview files in the current version of Excel, Box does not support previewing older versions of most Excel file types.
- You cannot preview password-protected files.
- Hyperlinks now work in PowerPoint files in Box preview on either the Web, or mobile applications for newly uploaded documents. If links are not working, try re-uploading the document.
- Videos embedded in PowerPoint files do not work in Preview.
- Business accounts are limited to a video resolution of 480 pixels in Preview.
- Animations and page transitions in PowerPoint do not work in Preview.
- Adobe PDF Portfolios are not supported by Box Preview.
- Small sized files (1-byte) cannot be previewed on the web app.
- Box does not support the previewing of PowerPoint files containing charts, tables, or graphics embedded from LibreOffice. To preview these files, download and view them locally.
- Microsoft Office Preview and Word Online do not follow time information in the original file:
- When previewing in Box, the time-related functions (for example, TODAY() or NOW()) may not display accurately. This is because Excel date and time functions are dynamic, while the previewed document is static. Box preview obtains and displays the date the file was previewed. A static version of the time/date is displayed in the previewed document, based on the time the preview was generated.
- Date values with the custom format “yyyy/m/d (aaa)” may show incorrect dates. This is due to a bug in the library that Box Content Preview has a dependency on. The workaround is to use a different format such as “yyyy/m/d (ddd)” or “yyyy/m/d”.
