Box Drive does locally cache files that you have opened. Box Drive’s cache size limit is based on your free disk space (50% of available space) and has a maximum limit of 25 GB. If you reach this limit, Box Drive begins removing files, starting with those files that have gone the longest without your accessing them. Also, if a cached file has a new version created on Box, Box Drive discards the locally cached version.
Admin Functionality
Virtual Desktop Support
* Appropriate only if you are running on a client PC (not on an RDS/Terminal Services server). In addition, you must enable client drive mapping from the RDS/Terminal Services server to save content into Box.
Related Links
Uninstalling Box Sync when you install Box Drive
Installing and Updating Box Drive
Large Scale Deployments of Box Drive
Box Sync Troubleshooting Basics
Download Box Drive
Using Box Drive Basics
