Box Hubs admin reports display the details of the Hubs in your enterprise. Reports are exported as .csv files to your Box Reports folder when complete.
Apart from running a report, you can save its configuration, schedule it, and subscribe specific users to it.
Box Hubs report details
- File format: comma-separated value (.csv) file
- Filename format:
hubs_run_on_YYYY-MM-DD-HH-MM-SS_[A|P].csv
Box Hubs report columns
In the generated Box Hubs report you can find the following columns:
Hub ID
A unique identifier for the hub.
Hub Name
The name given to the Hub.
Hub Description
Any description entered when creating or editing the Hub. Will be blank if no description has been added.
Creator ID
A unique identifier ascribed to the person who created the Hub.
Creator’s User Name
The username of the individual who created the Hub.
Creator’s Email
The value in the Email field in User Account Details of the individual who created the Hub.
Created Date
The date that the Hub was created.
Number Of Total Views
The total number of times the Hub has been viewed, including repeat views.
Last Viewed
The date that the Hub was last viewed by any user.
Last Updated
The date that the Hub was last updated by any user. Last modified on July 8, 2026
