Box Canvas enables you to create visual whiteboards as a creative and flexible way to collaborate with anyone, in real time or asynchronously. You can use it to visualize your team’s latest project, create mind maps, host engaging, interactive trainings and workshops, or to note down all your creative ideas. Box Canvas is integrated into your Box Content Cloud. Intuitive toolset, easy navigation, unlimited Canvases, great security solutions, and integration with other Box Content Cloud products make Canvas a perfect tool for working in all circumstances: whether your team is co-located, hybrid, or fully remote. With Box Canvas, you can:
  • Create unlimited whiteboards,
  • Securely share your Canvases with anyone, anywhere,
  • Work simultaneously or asynchronously,
  • Add various objects to your Canvas:
    • Sticky notes - use them to brainstorm and vote for your favorite ideas with your team,
    • Shapes - add various shapes to your Canvas to map out a process flow or create diagrams,
    • Text input - add and move text anywhere on your Canvas,
    • Connectors - use them to connect ideas, or combine them with shapes to map out flows,
    • Pen drawing - use it to free-form draw or scribble your thoughts onto the Canvas,
    • Icons - use them to create more efficient and effective wireframes and mockups,
  • Upload images - upload png, jpg, jpeg, and bmp images to bring your Canvas to life,
  • Use templates - use one of the pre-made templates to get started faster on Canvas.
Known issues
  • If a collaborator on a Canvas changes their name, the change is not reflected on the Canvas screen.
Last modified on September 10, 2026
