This article describes how to manage the lifecycle of Box Automate workflows, from admin enablement to end-user management and long-term governance.
Managing your workflows
After Automate is enabled, you can create, edit, and monitor personal or team workflows from the Box web application.
Creating and editing workflows
  1. In the left sidebar, click Automate.
  2. To create a workflow, click New+.
  3. To edit an existing workflow, open it and select Edit.
  4. Adjust triggers (for example File Uploaded) and outcomes (for example Move File).
  5. Click Activate to begin the automation.
Use descriptive workflow names so their purpose is easy to see in the management dashboard.
Workflow tracking
You can review recent workflow activity to confirm runs completed successfully. If a workflow fails, check the activity log for errors related to file permissions or folder paths. To monitor activity:
  2. Find the workflow. In the Status column, click Tracking.
Workflow sharing and collaboration
Sharing a workflow
When you create a workflow, you are its Owner. You can invite collaborators to help build and manage it.
  1. Go to Automate and open the workflow.
  2. In the header, click Share.
  3. Enter a Box user or Box group.
  4. Choose a role: Editor, Viewer, or Initiator (where available).
  5. Click Send.
Collaborator roles
  • Owner — Full control, including ownership transfer. Only one owner per workflow.
  • Editor — Can modify workflow logic, share the workflow with viewers and initiators, as well as publish and deactivate the workflow.
  • Viewer — Can view configuration and execution history only.
Permissions by role
*Editors can add or remove viewers and initiators but cannot change the owner.
Sharing a workflow does not grant access to the files and folders referenced in it. Collaborators only see content they already have permission to access in Box.
A Box Agent outcome and a custom agent outcome run as the workflow owner. The agent can use content the workflow owner can access.
Content permissions in shared workflows
  • Collaborators only interact with files and folders they can already access in Box.
  • Removing a collaborator from a workflow does not remove their Box permissions on those items; the workflow can continue to run.
  • The role a user has when they first assign a file or folder in the workflow definition determines what the workflow can do with that content and cannot be changed after the initial assignment.
  • When sharing a workflow, workflow editors can act on the existing file and folder permissions already configured in the workflow. Any outcomes an editor adds or modifies operate under those existing permissions.
  • If a workflow editor adds a new folder to the workflow, the workflow owner and other editors act on that folder with the permissions the workflow editor has on it. Additionally, the workflow owner receives viewer access to all content in the workflow they previously didn’t have permission to access.
Workflow sharing is available within the same enterprise only. Concurrent editing is not supported; only one user can edit a workflow at a time.
Governance and lifecycle management
Deactivate or delete workflows that are no longer needed to avoid unintended actions on content.
Deactivating and deleting workflows
To deactivate:
  1. Click Automate in the left sidebar.
  2. Find the active workflow, open the More options (ellipsis) menu.
  3. Select Deactivate.
Deactivating stops future triggers but does not stop runs that are already in progress. Delete permanently removes a workflow and its history and cannot be undone.
Ownership transfers
If an owner leaves the organization, transfer ownership of critical workflows to another user to avoid interruptions.
Last modified on October 23, 2026
