Visual workflow builder
You can build workflows using a visual builder that supports a robust set of triggers, conditional branch routing, parallel and merge branches, loops, dynamic variables, and agentic steps.Triggers
Triggers define what starts a workflow. Supported types include:- File or folder events
- Task completion or status changes
- File Request
- Metadata changes
- Box Forms submissions
- Manual start
- Box Sign requests
- Scheduling
Outcomes
Outcomes define what happens when a workflow runs:- File and folder actions — move, rename, copy files, or create folder structures
- Metadata actions* — apply, update, or extract metadata using AI
- Task and notification actions — assign approval or general tasks and send email notifications
- Box Doc Gen** — generate documents from templates
- Box Sign** — route documents for e-signature
- AI Agent outcomes** — run custom AI agents or Box Extract agents for metadata extraction at scale
- Multi-agent orchestration — coordinate multiple AI agents in a single workflow
- HTTPS Request** — call external APIs directly from a workflow
Agentic AI
Box Automate brings AI directly into your workflows with AI agents, automated metadata extraction, AI-based routing, human-in-the-loop validation, and continual learning that adapts to new document formats over time. Including an approval task to review AI outcomes can help ensure accuracy.Querying AI agents inside Automate workflows is charged against AI units. Contact your Box administrator to check your AI usage limit.
Collaboration and administration
You can share workflows with role-based permissions and track workflow runs.Integrations
Box Automate connects natively with Box Forms, Box Doc Gen, Box Sign, Box Extract, Box Hubs, Box AI Studio, and Box Apps.Known limitations
Templates are not available for Box Automate.Classification
If the classification policy set within the Admin Console restricts Apply Classification to the Owner role, all Apply Classification outcomes in Automate workflows are blocked from running.Workflow runs
- Max 10 branches (including ELSE) and max 20 conditions per IF are supported.
- Workflow deactivation does not terminate workflows that are already in progress.
- The Agent outcome works only when a File/Folder ID is referenced, not the name.
- When the folder or enterprise setting is Only folder owners and co-owners can send collaborator invites, the following outcomes fail:
- Task Assignment
- Add/Remove Collaborator
- Lock and Unlock
- Move, Copy, and Create folder operations
- Apply Classification when the policy requires higher privileges
Collaboration and permissions
- The Add/Remove Collaborator outcome does not support external email addresses and groups.
- Groups with permission type Admin and Group members are not yet supported in the outcome in Automate.
Variables and metadata
- There is no support for metadata from Current Outcome. As a workaround, use a metadata variable without linking to an outcome ID.
- Hidden metadata templates are not supported in the Add Metadata outcome or metadata conditions.
- You cannot add all metadata form field values to created files or folders as metadata without mapping them individually.
Box Sign integration
- Sign does not support tracking status via metadata for in progress status.
- The Sign outcome supports only signers from the email field in Forms, not from any text field.
- There is no File Name variable from the Sign outcome.
Automate interoperability
- Automate workflows are not fully interoperable with Box features such as Information Barriers, Governance, Box Shield, Box Zones, and Box Keysafe.
- The Move and copy content to a folder control in the Admin Console (Prevent collaborators from moving or copying content to a folder where they have a higher permission level), as described in Enterprise Settings: Content & Sharing tab, does not apply to Automate workflows. Moving or copying content into folders via an Automate workflow may still result in some users being granted a higher permission level. You can mitigate this by allowing users to create workflows only on folders where they have Owner or co-owner permission in Box Automate enablement settings.
