Enterprise settings define how Box works in your enterprise, and the settings in the Security tab define settings for security and access to Box.
Signup and Login
This section allows you to set up options for managed users to create accounts and sign in.
Self signup
Available only if you have defined a custom URL for your enterprise, which you do in Enterprise Settings > Custom Setup > Company Profile > Custom Subdomain. Allows people in your enterprise to create their own managed user Box accounts, as well as allowing admins to create managed user accounts. This can be a good option if you’re not concerned about your seat count. If you enable this option, you may also want to enable the Account Creation Notification option.
If SSO Required is enabled, you cannot enable this option.
Determines if an email notification is sent to all Box admins and co-admins in your enterprise when a managed user account is created. When you select this option, also select the notification frequency:
  • Immediately (default): To have a notification sent as soon as a managed user account is created.
  • In daily summary emails: To have a notification sent once per day with a list of all managed user accounts created during the past day.
You may not want to select this option if you have not selected the Self signup option because without self signup, only admins can create managed user accounts.
User email/login
Select this option to prevent users from changing the email address in their managed user account.
Failed logins
Determines if an email notification is sent to the primary Box admin in your enterprise after a set number of failed login attempts over any amount of time of a managed user account. When you select this option, select also how many failed login attempts must occur before a notification is sent. You can select any number from 3 (default) to 8.
Multi-Factor Authentication
This section allows you to define requirements for multi-factor authentication (MFA) and 2-factor authentication (2FA), or 2-step verification, for managed users and external users who log in with a username and password. (This MFA setting is not available if you use single sign-on (SSO) because in that case, multi-factor authentication is configured by your SSO provider.)
Managed Users
Require multi-factor authentication for all managed users
Determines if multi-factor authentication is required for all managed users when logging in to either the web app or the mobile app. When you enable this option, you must also select an Authentication Method for managed users.
When you enable Require multi-factor authentication for all managed users, you also decide what authentication method(s) are allowed:
  • Allow all methods: (Default) Allows any method for your managed users to use when additional authentication is required, by using a one-time password generated by the TOTP algorithm in an authenticator app, a physical security key, by a one-time password sent by SMS, which is less secure, or by sending a code to the user’s email for logging into a Box account.
  • Limit to selected methods: Determines which methods your managed users can use when additional authentication is required. You can select up to three:
    • Security Key: (Required) A physical device used as the possession factor in multi-factor authentication. Security keys compatible with Box must support the FIDO2/WebAuthn standard.
    • Authenticator app (TOTP): (Required) A one-time password generated by the TOTP algorithm in an authenticator app.
    • Text message (SMS): A one-time password sent by SMS, which is less secure.
    • Email: A code sent to the user’s email for logging into a Box account.
Authentication Frequency
When you enable Require multi-factor authentication for all managed users, you also decide how often your managed users (including your Admin and all Co-Admins) will be required to authenticate with the selected additional authentication method when they log in:
  • Every login
  • Custom frequency (default), then select a number of days or hours (with hours, you can select from 2 to 47, with days, you can select from 2 to 90, and the default is 30 days)
External Collaborators
Require 2-step verification for external collaborators
Determines whether external collaborators must use 2-step verification. Select Configure to open the 2-Step verification for External Collaborators dialog. In that dialog, set the authentication method, the requirement level, and enforcement together. The dialog includes this note: “Depending on the size of your enterprise, implementation time for this feature may vary.”
Authentication Method (External Collaborators)
In the 2-Step verification for External Collaborators dialog, under Authentication Method, select a 2FA authentication method:
  • Authenticator app (TOTP) or Security key: The default and recommended option. External collaborators authenticate with a physical security key, or with a one-time password generated by the TOTP algorithm in an authenticator app.
  • Authenticator app (TOTP) or Text message (SMS) or Email or Security key: External collaborators authenticate with a physical security key, a one-time password sent by SMS (which is less secure), a one-time password generated by the TOTP algorithm in an authenticator app, or a code sent to the user’s email.
(Configure) 2-Step Verification for External Collaborators
The same 2-Step verification for External Collaborators dialog sets which external collaborators require 2-step verification and when enforcement starts. Requirement Level Select from:
  • Disabled: 2-step verification is not required for external collaborators.
  • Enable for all external collaborators: Require 2-step verification for all external collaborators.
  • Enable only for select domains or users: Require 2-step verification only for external collaborators in the Domains field.
  • Enable for all external collaborators except select domains or users: Require 2-step verification for all external collaborators except those entered in the Domains field.
Domains When Enable only for select domains or users or Enable for all external collaborators except select domains or users is selected, a Domains field appears. Enter one or more valid email addresses or domains. Press Enter after each email address or domain. Enforcement Select from:
  • Enforce immediately: Require 2-step verification for the external collaborators you define as soon as you save 2-Step Login Verification settings.
  • Enforce on a future date and send notification warnings to existing affected users: Require 2-step verification for the external collaborators you define on the Enforcement Date you select.
If you select Enforce on a future date and send notification warnings to existing affected users, Box sends notification email messages to the external collaborators affected:
  • If Enable only for select domains or users is selected, Box sends notification email messages to any email addresses listed in the Domains field, plus all email addresses from any domain in the Domains field that exist as external collaborators in your Box enterprise.
  • If Enable for all external collaborators except select domains or users is selected, Box sends notification email messages to all external collaborators except the ones whose email is listed in the Domains field or who have email addresses from any listed domain.
If you select Enforce immediately, Box sends an email to external collaborators and enforces 2FA immediately. While enablement is in progress, you cannot edit the configuration. If you try to edit the configuration before enforcement is active, Box displays the message “Enablement in progress, please try again later.”
If this message still displays after 24 hours, contact Box Product Support.
If you select Enforce on a future date and send notification warnings to existing affected users, external collaborators affected by the configuration receive up to four notifications:
  1. Within a few hours after you select Save.
  2. One week before enforcing 2FA.
  3. One day before enforcing 2FA.
  4. The day of enforcing 2FA.
External collaborators can enroll in 2FA before the 2FA requirement is enforced. You can edit the 2FA configuration, including the enforcement date, any time before the configured enforcement date. If any additional external collaborators are added in your Box enterprise before the selected date and will be affected by this configuration, they will also receive a notification email message with information about the future 2-step verification requirement.
  • To change the enforcement date, you must first disable 2FA.
  • Edits to an existing configuration are enforced immediately.
  • In the Security Logs report, Box includes a record of all configuration changes made by admins. You can generate the Security Logs report from the Reports window of the Admin Console.
  • After setting 2FA configuration as Enforce on a future date, admins can subsequently either change the enforcement date or cancel altogether.
  • If folders with external collaborators are deleted up to two weeks before the 2FA enforcement date, collaborators will receive 2FA notification warnings even after the folders have been deleted.
Password Requirements
This section allows you to define password requirements.
If your enterprise account is SSO-enabled, these password settings apply to a user’s external “Box-specific password,” not the user’s SSO password. This is also where you can require strong passwords for external collaborators.
Minimum required characters
Defines the minimum number of characters required for passwords. Select from:
  • 6
  • 7
  • 8 (default)
  • 10
  • 12
Require Number(s)
Determines if numbers (numerals, characters from 0 to 9) are required for passwords, and if so, the minimum number required. This counts towards the minimum number of characters required. Select from:
  • 1
  • 2 (default)
Require special character(s)
Determines if special characters (non-alphanumeric characters such as ! @ / $ &) are required for passwords, and if so, the minimum number required. This counts towards the minimum number of characters required. Select from:
  • 1 (default)
  • 2
This option is cleared as its default value.
Require at least one uppercase letter
Determines if at least one of the alphabetic characters required for passwords must be uppercase (a capital letter). This option is cleared as its default value.
Prevent common words/email address as a password.
Determines whether you prevent users from choosing common words or email addresses as passwords. Using common words or words in the dictionary or using email addresses makes it easier for unwanted users to guess passwords and to log in to your users’ accounts. Box recommends selecting this option (its default value), which will make your users’ accounts more secure.
Require users to reset passwords every [number] days
Determines whether you require users to reset their passwords every selected time period. If selected, on the next login after the time period selected past a user’s previous password reset, Box prompts the user to reset their password before allowing them to log in. This setting’s behavior is retroactive, so if a user hasn’t reset their password for 90 days and you set a new policy of 30 days, at the user’s next login Box prompts the user to reset their password before allowing them to log in. If enabled, select from:
  • 30 days (default)
  • 60 days
  • 90 days
Perform a global password reset now
Click to require all users and admins to change their passwords immediately.
Prevent reusing passwords from last [number] times
Determines if users are prevented from reusing passwords. If enabled, you can select any number from 4 (default) through 12.
Notify admins when users request a forgotten password email
Determines if all of your enterprise Box admins will receive an email when a user requests a forgotten password email. This option is cleared as its default value.
Notify admins when users change passwords in Settings
Determines if all your enterprise Box admins will receive an email when a user changes their password in their Account Settings. This option is cleared as its default value.
Require strong passwords (for external collaborators)
Determines if external collaborator accounts require strong passwords. With this setting enabled, passwords from external collaborators have to meet certain security criteria before the user will be able to access the content owned by your organization. A “strong” password is not the same as the one you define in the Password Requirements section, but it does meet the following requirements:
  • At least 8 characters
  • Include numerals, uppercase letters or special characters
This option is cleared as its default value. Box will send an email notification to new and existing external collaborators when you enable this setting, and they need to log in and change their password to access content owned by your organization. If they reject the password change, they will not be able to access content shared with them. If they decide later that they’d like to change their password to access the content, they will need to be invited again by a collaborator.
If your organization has SSO (single sign-on) enabled, but not required, external collaborators who are informed that they must use a strong password must still update that password to access shared content.
Exposed password detection
Exposed password detection compares user passwords against a database of credentials known to have been compromised in a third-party database of leaked passwords. If a match is found, Box takes action based on the settings below. SSO logins and social logins (such as Google sign-in) are exempt from exposed password detection.
Require password reset for Managed Users with exposed passwords
Determines if managed users are required to reset their password if the password they use to sign in has been found in a third-party database of leaked passwords. This setting is available for Enterprise plans and above. This setting is off by default. When this setting is on: If a managed user signs in with a password found in a third-party database of leaked passwords, they are blocked from accessing Box and prompted to reset their password. Box sends a password reset link to the user’s email address. When the user resets their password, Box scans the new password, which cannot be a known exposed password. When this setting is off: Managed users whose passwords are found in a third-party database of leaked passwords are not blocked from accessing Box. Instead, they see an in-product notification banner on the All Files page advising them to change their password, with instructions on how to do so. An informational banner also appears in Account Settings > Authentication.
Admins can manually generate a password reset link for managed users who cannot access their email from Admin Console > Users and Groups > Managed user > User Details > Edit > Password reset. For more information, see Users & Groups Settings.
Require password reset for External Collaborators with exposed passwords
Determines if an external collaborator is required to change their password before they can access content shared with them if the password has been found in a third-party database of leaked passwords. Enforced when external collaborators log in to the Box web app. This setting is off by default.
If this setting resets a collaborator’s status to Pending, they may not appear in the Collaborations report during the grace period. These collaborators are still at risk of automatic removal after 30 days if they do not update their credentials.
Session Duration for All Users
Determines the amount of time that managed users can be logged in to the Box web app with no activity, defined as any explicit user action, before being logged out automatically. The logout will occur upon the next user action after session expiration. Select an option from the second drop-down list first, from:
  • minutes
  • hours
  • days
Then select a number of minutes, hours, or days from the first drop-down list. The range you can select for each is:
  • 10 to 59 minutes (default is 10)
  • 1 to 71 hours (default is 1)
  • 3 to 90 days (default is 14)
If you do not make any selection, the default value is 14 days.
Session duration settings apply only to the Box web application. Any session duration limits set here do not apply to users accessing Box through any other Box endpoints (for example, Box mobile applications, Box desktop applications, Box Notes, etc.).
KeySafe
This section is visible only if your organization has added KeySafe to your Box service and if it has been configured by Box Support.
Enable KeySafe/KeySafe Enabled
  • If KeySafe is not enabled, this section contains an Enable button that you can select and enable KeySafe with either Amazon Web Services or Google Cloud Platform.
  • If KeySafe is enabled, you will see hints for your Amazon Web Services or Google Cloud Platform IDs. These cannot be edited in the Admin Console.
Last modified on October 15, 2026
