Control the content that is synced to your local Box Sync folder by marking content in your Box.com account. A folder that is marked for Sync displays a blue check mark icon beside its name.
synced-to-desktop-original-png
You must have Editor Access or higher to use Box Sync in a folder.
Marking a folder for Sync
To mark a folder for Sync, navigate to your Box.com account and follow the steps below.
  1. Select a folder by clicking beside its name, or click the folder name to open the folder. The right hand sidebar should display information about the folder you’ve selected or opened.
  2. Click Details in the sidebar.
  3. Click the Sync to Desktop slider to mark this folder for sync. By default, this will mark all contained folders for sync as well. You can unmark specific subfolders within a synced folder, if you only want certain content to be synced.
using-box-sync-1
Adding files and folders to the Box Sync folder on your computer will automatically upload them to your account on Box.com and mark them for Sync.
If you have content that appears in Box but is not appearing locally, the parent folder may be partially synced.
9nmuq6thpwhpmfmtd4dkvxf4p2ia6ucm
When a parent folder is partially synced (hovering over folder icon displays the This item is partially synced status), new subfolders or files created within this parent folder will not be marked for Sync automatically. To fully sync a partially synced folder, you must unsync the partially synced folder, then sync it again.
Viewing All Synced Items
You can view a list of all items marked for sync on the Synced page. Click Synced in the left hand sidebar.
marking-content-for-box-sync-png
Syncing Subfolders
The subfolder sync feature in Box Sync 4.0 allows you to selectively sync or unsync any subfolder in Box.
Using Subfolder Sync
  • Identify a directory structure in the Box website where nothing is synced.
  • In your Box website account, select the folder and mark it for sync. Verify the corresponding sync status in your Box Sync directory on your computer.
  • Within the folder, you can decide to only sync the one subfolder and unsync the other subfolders. Simply select the subfolder you’d like to unsync and ensure that the Sync to Desktop slider is disabled.
  • You cannot unsync individual files within a synced folder. If you sync a folder to your desktop, all individual files contained will be synced as well.
  • If you mark a subfolder for sync, its parent folder will be marked for sync as well, meaning that the individual files in that parent folder will be synced to your desktop in addition to the marked subfolder. No unmarked subfolders contained by the parent folder will be synced.
  • Any subfolder created in a parent folder that is partially synced will not be synced by default. New folders created in that same directory on Box will be unmarked for Sync by default.
Problem Files
Some files cannot be synced to Box. If you attempt to sync these files, the file will not be synced, and you will receive an error notification. For more detailed information on these error messages, check out which file types are ignored or blocked or read basic troubleshooting steps here.
