In the Box Notes web interface, you can open or search for any Box Note that you have access to.
Opening Box Notes
- From your Files page, in the lefthand navigation select Notes to open your default Box Notes folder.
- Select the folder icon in the upper left corner of the toolbar.
- In the window that opens, select the Box Note you would like to open by selecting the bubble beside its name. You can also search for a Box Note using the search bar in the pop-up. Select Choose when you have selected a Box Note.
To return to a previously opened Box Note, access it from your Recents.
Searching Box Notes
Box Notes includes a redesigned quick search with improved results to help you find notes faster.
- Select the search icon in the upper left.
- Enter your search terms in the search bar that displays. Results update as you type, surfacing the most relevant notes.
- Select a result to open that note.
Last modified on September 2, 2026
