This functionality is separate from the iOS passcode presented at the Home Screen of your iOS device. That code allows access to your full phone, while the passcode mentioned in the article only controls access to the Box for iOS application.
Enabling the Box for iOS App Passcode
To enable the passcode, please follow the steps below:- Log in to the Box for iOS application.
- Tap the Gear icon in the top-left corner to access Settings.
- In the Settings, select Security.
- Tap Turn Passcode On.
- Choose a passcode and enter it on the number pad.
- Confirm your passcode.
- If you would like to change the time limit to prompt the Passcode, tap the Lock setting and choose the time setting you prefer.
Enabling TouchID or FaceID
Box also allows users to leverage the iOS functionality TouchID or FaceID once they have a passcode set. Here is how to enable this feature:- Once the passcode is set, return to the Security Option page.
- Enable the TouchID/FaceID setting.
- Complete the TouchID/FaceID prompt to confirm the setup.
