While browsing all files and folders in Box, uploading a new file or folder is straightforward:
  1. In the Files section, select New + button in the upper-right corner.
    new-plus-button-png
  2. Select File Upload or Folder Upload, depending on what you’d like to upload.
  3. Select the file(s) or folder you’d like to upload.
  4. You can select multiple files for upload by holding the Command or Control key (Mac or Windows, respectively) while selecting files. However, you can only select one folder at a time for upload.
  5. Select Open or Upload.
If your session is interrupted, Box allows you to later resume uploads of files that are over 100 MB in size using the Uploads Manager. The Uploads Manager appears at the bottom of the screen when you start uploading files or folders. To resume an interrupted upload:
  • In the Uploads Manager header click Resume All, or
  • In the Uploads Manager click Resume.
Uploads Manager showing failed uploads with Resume All button highlighted.
To cancel a current upload:
  1. In the Uploading dialog window, select Cancel All. Box displays the Cancel All Uploads dialog window.
  2. In the Cancel All Uploads dialog window, select Cancel All.
If you are having trouble uploading files, here are some possible issues and solutions:
Last modified on July 23, 2026
