A Description can be added to Folders or Files on the Box Web Application, as long as you have Editor access in the folder. 255 characters is the maximum character limit for the Description field.
Folder:
  1. Click the folder (do not open the folder).
  2. In the right pane under Details, you will see the Description where you can enter or modify a description.
fo-png
File:
  1. Click the file (do not Preview the file).
Box folder view with Details pane showing Enter a description field.
Last modified on July 10, 2026
