To help keep your organization’s content secure, Threat Detection rules need to be configured and enabled. In some rule types, you can include multiple values, such as of IP addresses, domain, locations, or email addresses. You might therefore want to create a Shield list of those values instead of adding all the individual values to the rule.
Create a threat detection rule
To create a threat detection rule:
  1. Navigate to Admin Console > Shield.
  2. Select the Detection Rules tab.
  3. Select Enable for the detection rule you want to configure and start.
  4. Enter a Rule Name. This should be a short, unique, and descriptive name with a maximum of 80 characters.
  5. Enter a Description (optional). Enter an optional description of a maximum of 255 characters, that provides a summary of the rule purpose and function.
  6. Certain rule configurations vary depending on the rule:
    • Malicious Content, decide if you want to enable deep scan and download restrictions.
    • Suspicious Location, click Add Rule to configure locations and activity to monitor, whether to restrict target user access, and decide which filters to enable.
    • Suspicious Session, decide which filters to enable.
    • Ransomware Activity, decide whether to automatically terminate the target user’s sessions when an alert is triggered.
  7. For Suspicious Location rules only, select an Alert Severity. Every alert the rule generates has this severity. Select from:
    • Low
    • Medium
    • High
    • Critical
    For all other rules, Shield calculates each alert’s severity from its risk score.
  8. Select whether to enable any rule specific settings, where applicable.
  9. For all rules, decide whether to toggle:
    • Publish alerts to Box Event Stream: Enable this to allow alerts from this rule to be forwarded to a third-party tool, such as a SIEM or CASB tool, via the Box Event Stream. The default state is disabled.
    • Send Notifications: Enter one or more email addresses or managed usernames to receive email notifications of alerts. The only email addresses or managed usernames you can enter in this field are co-admins who have at least one Shield permission enabled in their user account settings.
    • Box AI Threat Analysis: When enabled, Box AI will provide a summary of generated alerts.
  10. Once complete, select Next.
  11. Review the rule settings then select Start Rule.
Edit a threat detection rule
To edit your threat detection rule:
  3. Select the rule.
  4. Select Edit, then Update Rule after implementing changes.
Delete a threat detection rule
To delete your threat detection rule:
  3. Select the rule.
  4. Select Delete.
After selecting Delete, there is no confirmation screen. The detection rule is instantly deleted.
Last modified on October 27, 2026
