Use the Admin Console to control which Box MCP server tools are available across your enterprise, and to set security guardrails for selected write tools. This helps you meet your organization’s security, compliance, and governance requirements.
How tool access works
Box MCP server tool access works at two levels: enterprise-wide, and for an individual integration or platform app. By default, every published integration and unpublished platform app follows your enterprise-wide configuration. That default stays in effect until you set a Custom configuration on the Box MCP Server tab of an individual integration or app, which then takes precedence for that integration or app only. Box applies settings in this order:
  1. Custom configuration — When set on an integration or platform app, it applies to that integration or app only.
  2. Global configuration — Applies to any integration or platform app that doesn’t have its own custom configuration.
Because settings can differ from one integration or app to the next, the same Box MCP server can expose different tools depending on which AI platform is in use.
Enterprise-wide access
Global configuration applies to every user, and to any integration or platform app that doesn’t have its own custom configuration. To open your enterprise-wide tool settings:
  1. Open the Admin Console.
  2. In the left sidebar, select Integrations.
  3. Select the Box MCP Server tab.
A table displays each tool category with its current access level and a Configure button. From here, you can manage access:
  • By tool category
  • By individual tool
  • Or both
Box MCP Server tab in the Admin Console showing tool categories, each with an Enablement dropdown and a Configure button.
Some categories, such as Box Hubs or Box AI & Agents, might not be available for every enterprise. Check your subscription for details.
Set category access
To set access for an entire category:
  1. In the Box MCP Server table, find the category you want to configure.
  2. Select its Enablement dropdown.
  3. Select one of the following access levels:
    • Disable all tools — No tools in the category are available.
    • Enable read only tools — Only tools that read data are available.
    • Enable read & write tools — All tools in the category are available, including tools that create or modify data.
    • Custom configuration — You choose which individual tools in the category are available.
After that, category-level changes take effect immediately.
Set individual tool access
To control access to specific tools within a category:
  2. Select Configure.
The configuration window lists the category’s tools under Read only MCP tools and Write MCP tools, each with its own toggle.
Category configuration window with individual tool toggles grouped under Read only MCP tools and Write MCP tools.
The Enablement selection and the individual toggles stay in sync:
  • Selecting an Enablement option updates every toggle in the category.
  • Changing an individual toggle updates the Enablement selection:
    • Enabling only read tools selects Enable read only tools.
    • Enabling all tools selects Enable read & write tools.
    • Disabling all tools selects Disable all tools.
    • Any other combination selects Custom configuration.
After you select Save, a confirmation message displays.
To find a specific tool without browsing categories, select the search bar at the top of any Admin Console page, enter a keyword, then select a result. The Admin Console opens the relevant category configuration.
Access for one integration or app
You can also set tool access for a specific integration or platform app, overriding your enterprise-wide default for that integration or app only. This enables you to govern each AI platform separately while keeping one enterprise-wide baseline for everything else. Every integration and platform app has its own Box MCP Server tab, where you choose how it gets its tool access:
  • Global configuration — It inherits your enterprise-wide settings. This is the default.
  • Custom configuration — You set tool access for this integration or app only, overriding the enterprise-wide settings.
When you select Custom configuration, the tool categories display, and you can expand any category to enable or disable its individual tools.
A custom configuration applies to every user who has access to the integration or app. Per-user and per-group controls aren’t supported.
Where you find the tab, and how your changes take effect, depends on the type of app.
Set tool access for an integration
  3. Find the integration you want to configure. To narrow the list, filter it to the MCP category or search by name.
  4. Select Configure for that integration.
  5. In the window that opens, select the Box MCP Server tab.
  6. Select Custom configuration.
  7. Select a category to expand it, then use each tool’s toggle to enable or disable it. To narrow the list to a specific scope, select the All, Read only, or Write only filter above the categories.
  8. Select Save.
Box MCP Server tab for the Claude integration with Custom configuration selected, showing the All, Read only, and Write only filters and the expanded Files and Folders category with individual tool toggles.
To return the integration to your enterprise-wide settings, select Global configuration, then select Save.
The Box MCP Server tab controls which tools an integration can use. To control whether managed users and groups can access the integration at all, use the Availability Status tab instead. Both tabs have a Custom configuration option, but they govern different things.
Set tool access for a platform app
  2. In the left sidebar, select Platform.
  3. From the top of the window, select the Platform Apps tab.
  4. Find the app you want to configure, then select its name.
  5. On the app details page, select the Box MCP Server tab.
  7. Select a category to expand it, then use each tool’s toggle to enable or disable it. Your changes apply immediately.
To return the app to your enterprise-wide settings, select Global configuration. Box removes the custom configuration. The integration or app follows your enterprise-wide settings again, including any changes you make later.
When you disable a tool
When you disable a tool, either enterprise-wide or for a specific integration or platform app:
  • Box removes it from the tool list returned to the MCP client.
  • Agents can no longer discover or use it.
If you disable a tool after an agent has already discovered it:
  • Box enforces the change at runtime.
  • The Box MCP server returns an error such as:
Tool has been disabled by the enterprise admin. Contact your enterprise admin for more information.
During an active session, the user might instead see a generic error, such as “tool not found.” The exact message depends on the MCP client.
Some MCP clients cache the tool list. After you enable or disable a tool, an agent might still reference a cached list, either trying to call a tool that’s no longer available or not yet seeing a newly enabled one. If this happens, close and reopen the MCP client so it fetches an updated tool list.
Security guardrails for write tools
Security guardrails are available only for Enterprise Advanced accounts.
Security guardrails define the boundaries in which an AI agent can use selected Box MCP server write tools. Instead of turning a tool fully on or off, you can enable it and then restrict its use to specific content or users, depending on the tool. For example, you can allow file uploads only to specific folders, or block a tool from adding external collaborators. Guardrails help prevent agents from taking actions that could expose data, such as uploading, moving, copying, or sharing content, or that could disrupt your business, such as moving content out of place. Because agents can act autonomously and at scale, guardrails stop these actions before they run instead of detecting them afterward. When an agent calls a tool that has guardrails, Box evaluates the request against your rules before running it. If the request falls outside those boundaries, Box blocks the action. Guardrails use the same constraint types as guardrails in Box Automate:
  • Content Restrictions: Where the tool can act, for example in specific folders or Hubs, or on content with specific classification labels.
  • Managed User Criteria: Which managed users the tool can involve.
  • External User Criteria: How the tool can interact with external users.
For details on each option, including allowlists, denylists, and blocking externally accessible items, see Configuring advanced guardrails.
Supported tools
Guardrails are available for selected write tools in the Files and folders and Collaboration categories. To see which tools support guardrails, check the Guardrails column in Available tools. Guardrails don’t apply to read-only tools. To control which content agents can read, use Shield Smart Access policies.
Configure guardrails
You configure guardrails for each tool in your enterprise-wide Box MCP Server settings, when you enable the tool. You need the same admin permissions you use to enable and disable Box MCP server tools. To configure guardrails for a tool:
  4. Find the category that contains the tool, then select Configure.
  5. Under Write MCP tools, enable the tool, then open its guardrail settings.
  6. Set Content Restrictions, Managed User Criteria, and External User Criteria as needed. The available criteria depend on the tool. For details on each option, see Configuring Advanced Guardrails.
  7. Select Save.
Enterprise-wide guardrails also apply to integrations and platform apps that have a custom configuration, depending on where the tool is enabled:
  • If the tool is enabled both enterprise-wide and in the integration or app, the enterprise-wide guardrails apply.
  • If the tool is enabled only in the integration or app, and not enterprise-wide, no guardrails apply.
Guardrails don’t override enterprise-level or folder-level restrictions. The permissions of the user who connected the MCP client still apply on top of your guardrail selections.
When a guardrail blocks an action
When a request breaks a guardrail rule, Box doesn’t run the action. The Box MCP server returns a structured error to the agent explaining that a security guardrail blocked the action. Depending on the MCP client, the agent might display this error to the user or try a different approach.
Audit tool changes
To review when and how tool settings changed, including changes to a specific integration or platform app:
  2. In the left sidebar, select Reports.
  3. Select Create Report, then select Security Logs.
  4. Under Integrations, select Changed MCP Tools Enablement Status.
The report includes: For more information, see Security Logs Report. Box also logs every security guardrail configuration change to the enterprise event stream. To retrieve these events, use the Events API.
Monitor usage
Use these reports in Admin Console > Reports to review MCP activity in your enterprise.
Last modified on November 17, 2026
