Box Forms is available only for Enterprise Advanced accounts.
Building a form
Get started by going to the Automate section and then the Forms tab. From here, select New + to begin creating a form.
- Short Text
- Long Text
- Checkbox
- Radio
- Dropdown
- Number
- Currency
- Address
- File Upload
- Email Address
- Metadata
- Static Text
- Date and Time
- Select a theme color.
- Add a header logo.
Creating a multi-page form
Split a long form into multiple pages. The pages panel on the left side of the form builder lists every page in the form. Select a page to edit its fields. To add a page:- In the pages panel, select Add Page. Box adds a page named Untitled Page to the end of the form and opens it.
- On the canvas, enter a title and description for the page.
- Add fields to the page.
- In the pages panel, next to the page, select the ellipsis (…).
- Select one of the following:
- Move Up or Move Down to change the page order
- Duplicate Page to copy the page and its fields
- Clear Page to remove all fields from the page
- Delete Page to remove the page from the form
Adding a review step
In a multi-page form, you can add a review step that displays all of a submitter’s answers on a single page before they submit. From the review step, submitters can select Edit to return to a page and change their answers. To add a review step, turn on the review step setting in the form settings. This setting is available only when a form has more than 1 page.Adding form logic
Logic within forms can adapt based on user inputs, making them more relevant and easier to complete. You can set conditions to show or hide fields and add specific logic for further customization. To add custom logic: For the If condition, configure the logic that determines the event needed to trigger the conditions. Select to specify if All Conditions or Any Conditions apply: For the applicable field, select a condition operator:- Equals
- Does Not Equal
- Contains
- Does not Contain
- Begins With
- Ends With
- Is Empty
- Is Not Empty
- Show/Hide Fields
This outcome can be used to show/hide submitters relevant form fields as they complete the form. - Enable/Disable Fields
This outcome can disable fields to make them read-only while keeping them visible.
- Show/Hide the field.
- Enable/Disable the field.
In a multi-page form, each logic rule belongs to a page and can reference only fields on that page.
Saving a form
Select Save to save your progress. Each form must have a unique title. If a form with the same title already exists, the Form Title Already Exists dialog opens when you save the form or leave the Form Builder.
- In the Form Title field, enter a unique title.
- Select Save Form.
Previewing a form
Once a form is completed, you can select Preview to review the form prior to sharing it. From the Preview tab, you can test out the fields, conditions, and page navigation to ensure all work appropriately. Submissions in preview are not included in the form submissions page.Publishing a form
After reviewing the form, you can share it to gather submissions. (Optional) Select Settings and select if you want to require form submitters to log in to Box:- To allow only logged in Box users to create submissions, toggle on Require uploaders to log in to Box. If your admin has this setting enabled, then form submitters have to log in to Box by default.
- To allow anonymous form submissions, toggle off Require uploaders to log in to Box.
- Select Set a link expiration date.
- Select a date.
- Select Save.
Embedded links
To create an embed widget from your form- Select Copy. The toggle Link is enabled needs to be set to on to share the link.
- Navigate to the form.
- Select the ellipsis (…) on the specific form.
- Select Share.
- To the right of the link, select the code box.
