Beginning with v2.21, Box Drive supports the ability to lock (or) unlock files when a user opens (or) closes the document. Admins can enable this feature for their end users to help improve the collaboration experience for Box files when accessed by the user on their desktop.
Background
Box Drive currently provides the option to lock a file to ensure other users are not able to edit the document at the same time. To lock the file, right click it and select the lock option before you open the file. If you don’t lock a file, there may be conflicting copies of files created when multiple users try to save a document at the same time. See File Version Conflicts for details on how Box resolves conflicts such as these.
Enhanced lock/unlock experience
On Box Drive v2.21 and above, admins can enable the enhanced lock/unlock feature for their users. There are 2 configurations the admins can set - Automatic or Prompted locking.
  • Automatic Locking (AutoLockUnlock=1) - The file will automatically be locked/unlocked when the user opens/closes the file.
  • Prompted Locking (AutoLockUnlock=0) - When the user opens the file, they will receive a prompt asking if they want to lock the file. When the user closes the file it will automatically be unlocked.
Enabling the enhanced lock/unlock feature
Automatic locking option:
  1. Create a new DWORD (32-bit) value (REG_DWORD) using the Registry Editor tool under HKEY_LOCAL_MACHINE\SOFTWARE\Box\Box called AutoLockUnlock.
  2. Set the value of AutoLockUnlock to 1.
  3. Restart Box Drive.
Prompted locking option:
  2. Set the value of AutoLockUnlock to 0.
Disabling the enhanced lock/unlock feature
  1. Delete the AutoLockUnlock registry value from HKEY_LOCAL_MACHINE\SOFTWARE\Box\Box.
  2. Restart Box Drive.
Important factors:Support - Enhanced lock/unlock is supported only for the following:
    • Microsoft Word, Excel and PowerPoint 2010 and above.
    • Windows 10 (64-bit) and above.
    • Collaborated folders
Offline behavior
  • Box Drive does NOT support enhanced lock/unlock experience when the user is offline. Opening a file when offline will not automatically lock or prompt the user to lock the file. Similarly, closing a file when offline will not unlock it.
Auto-lock behavior
Known limitations
  • Drive will not be able to detect that file opens and closes when the Office application is opened with admin privileges. This is a system limitation without a workaround.
  • Users who have enabled Preview pane on Windows File Explorer will not receive the unlock prompt if Explorer is trying to fetch the preview for the file (when the file is selected when File Explorer is in focus).
User Experience
The below table lists the experiences for the different configurations for enhanced lock/unlock when accessing files on the Box Drive folder:
Flow Prompted Option Automatic Option
Lock a collaborated file
When a user opens an unlocked Word/Excel/PowerPoint file
User is prompted to lock the file. This prompt will also be displayed when a user saves a file to Box using Save As.
Note:
This prompt will be displayed when the Office application opens the file. The file is locked when the user clicks Lock File.
A Box Drive Lock Files dialog prompting the user to lock Customers.xlsx to prevent others from editing it.
File is automatically locked. The file is also locked when a user saves a file to Box using Save As.
A Box notification stating that customers.xlsx has been locked to prevent collaborators from editing until the file is closed.
Unlock a file
When a user closes a locked Word/Excel/PowerPoint file that they locked
File is automatically unlocked
Note:
If the user has made edits to the file, the file is unlocked only after it is uploaded to Box.
A Box notification confirming that customers.xlsx has been unlocked after the file was closed.
Note:
blobid2-png
File locked by a collaborator
When users open a locked Word/Excel/PowerPoint file.
User is notified that the file is locked by a collaborator, and the file will open in read-only mode.
A Box Drive dialog informing the user that Business Plan.pptx is locked by a collaborator and will open in read-only mode.
blobid3-png
