- Go to https://www.box.com/box-for-devices/ and download the appropriate Box Tools installer for your operating system.
- Run the Box Tools installer, and follow the prompts to install or update Box Tools on your computer.
- If you use the Safari browser (macOS only), you’ll need to perform the following additional steps:
- In main menubar at the top of the Safari window, click Safari then select Settings.
- In the Extensions tab, check Box Tools. If Box Tools is not listed, relaunch Safari and start again.
- In the Extensions tab, with Box Tools checked, click Edit Websites.
- Set Box.com to Allow.
Installing Box Tools
Box Tools is the installer package for both Box Edit and Device Trust functionality. The Device Trust component is used only if your administrator has enabled Device Trust for your Box account.
Before installing Box Tools, ensure your .NET framework version is .NET 4.8 or higher.
To install Box Tools on your computer:
Last modified on May 25, 2026
