This article is about Box Shuttle as a standalone tool. If you are using Shuttle in Admin Console, see this document.
Introduction
Every migration is unique, and it can be tricky to move data between differing systems. Box Shuttle enables a simple and powerful path from wherever your content is stored today into Box, allowing you to transfer folders, files, permissions, and metadata. This guide provides instructions for moving data from Google Drive and focuses on how-to procedures, best practices, and configuration steps.
This guide applies to migrations from Google Drive associated with a Google Workplace account, not personal Google Drive accounts or Google Cloud Storage. If you are looking to migrate from personal Google Drive accounts, contact your Box account team for guidance.
Google Drive migration concepts
The following sections will help you understand Google Drive migration concepts before you start analyzing and migrating your data.
Google Drive
Google Drive is a cloud provider operating from drive.google.com.
Account mapping
Account mapping is used for associating a source user account with a target user account. Matching accounts simplifies transferring multiple user files and folders without users losing access to the content. This is an essential component to migrating permissions. Box Shuttle attempts to map users automatically. For example, a source account of username@mycompany.com on Google Drive automatically maps to a Box target account with the same name. Additionally, permissions assigned to groups such as Engineering, regional offices, or restricted-access entities such as Legal, map to their corresponding target groups. To accomplish this, Box Shuttle follows these steps:
  1. Audits all the users, groups, and permissions on the source when initially scanning the content.
  2. Scans target users and groups.
  3. Confirms the owner’s and collaborators’ permissions, paths on the target, and automatically matches according to best possible fit.
The Google Drive (Administrator/Service Account) system is required for account mapping. Next sections provide the details of account migration.
My Drives
If you select multiple Google source accounts for transfer, Shuttle will transfer the contents of each user’s My Drive. You can also transfer Shared Drives in the same job.
Box Shuttle only transfers items from drive.google.com. Items from other URLs, such as Google Photos (photos.google.com) are not supported.
Shared with Me space
Shuttle does not list or transfer content stored in the Google Drive Shared with Me space. For Google sources, each selected user’s personal account is transferred in a multi-user migration. In most cases, an item that resides in more than one place on the tenant will be transferred along with the account of the user who owns that item. If you select all accounts, Box Shuttle transfers one instance of each item in the entire Google tenant. Duplicate instances of that item in other locations will be consistently filtered so that only one instance of each item is transferred.
Alias emails
Alias emails are alternate emails to the primary email for a given account. These may be due to historical changes in the Google account. For example, this includes relevant email domain changes from subsidiary.com to parentCompany.com with users receiving new email accounts. In addition, instances with users needing two emails for the same account also apply. When migrating data from Google Drive, this can result in file conflicts. Former items may be shared with joe@subsidiary.com and newer items would be shared with joe@parentCompany.com. These items are actually shared with the same source account. Box Shuttle checks the IDs of user metadata associated with owners and contributors. This merges aliases with the current primary email for the account. In this example, any files shared with the joe@subsidiary.com are listed as being shared with joe@parentCompany.com in the mapping spreadsheet and in Box Shuttle reports. Prevent errors during the migration and update primary emails of user accounts before any analysis or transfer job.
Externally-owned data and collaborators
Box Shuttle does not support external owners or collaborators. Any data that has external owners will not be migrated. External collaborators cannot be migrated and will need to be added to data post-migration.
Google Docs migration
Google hosts pseudo files, such as Google Docs, that are stored in a database and rendered as files in the Google Drive UI. Box Shuttle automatically exports and transfers docx, xlsx, pptx, svg and txt files from Google Docs, Sheets, Slides, Draw and Sites files respectively. Please reach out to Box Consulting if you need to migrate Google Docs without conversion.
Maps and Forms are not exported and are not transferred.
To ensure Google Docs are migrated properly:
  • Complete all Google Doc edits and allow ample time for saving before any transfers.
  • Avoid editing documents during any active transfers. Documents going through the save process may result in additional files on the target with (Conflicted Copy) in the file name. If a Google Doc is updated on the source after the initial transfer, a resync run transfers and exports the updated content.
Box Shuttle uses Google’s export tool to export Google docs and may encounter files that cannot be exported. Files with export errors are documented in the transfer report. For details, see Google Drive export errors.
Suspended users
To transfer Google Docs from a source, only active users are supported. Suspended accounts are not compatible, and can result in permission errors on export that leads to transfer file failure.
Versioning in Google Docs
Google Docs may also include file versions. Unlike true files, Google Docs versions are not stored as separate files. These are stored and accessed within the document itself. This is similar to Box. Box Shuttle lists Google Doc versions in the analysis report. These versions are transferred when Google Docs exports to Office on the target with the Sync File Versions job selection. Versions are listed in reports for analysis, simulation, and transfer jobs.
Converting unique Google properties to other platforms
Forward slashes in file and folder names
Forward slashes (/) are commonly used in file and folder names on Google Drive. This may conflict with moving to other service providers. The forward slash character is invalid and reserved for use as a delimiter of directories and files in data paths. Box Shuttle converts forward slashes to divider slashes U+2215 for all Google Drive sourced migrations. This character replacement is displayed in the file chooser, simulation, and transfer reports. Similarly, trailing and leading spaces in file or folder names are also converted to a character that looks like a space visually, but is actually a different character that Box supports.
Duplicate named items
Google Drive supports files and folders with duplicate names. For two or more folders or files with the same name, Box Shuttle appends a unique ID to the name. For example, an item with the name Content1 transfers as Content1 and any later named items with the same name also include an appended ID, such as Content1 (abcdefg12345). If you have a folder and file with the same name, they transfer to Box with their names intact. Please review your simulation results carefully.
Sources and targets
The source is where the data is today. This is a starting point for the data in the migration process. Box Shuttle cannot alter or modify your source data. The target is an end destination – Box. This is where the data is at the end of the migration process. A target can be one or more different user accounts.
Jobs
A job is a task to move one group of data from a source into Box. A group of data is whatever makes sense to your business - it might be a department, a single user, or a particular folder - that’s up to you. In the migration context, the term job applies to migrating data from the source to a Box target. Box Shuttle offers two job types:
  • Analyze Data jobs help you start planning your migration. These jobs analyze every item specified in your source and provide a robust report.
  • Migrate Data jobs move and transfer data. These jobs include:
    • Data-only migration that migrates your data to a single location on the target without migrating permissions.
    • Migration with permissions that transfers not only data, but also ownership rights and permissions from one location to another.
Prepare your Google account
Unlike most service providers, Google Drive requires more information than a username and password. Google as a provider does not support OAuth authentication, instead supporting JSON Web Tokens (JWT). That’s why you need to follow these steps to prepare your Google Drive account for Box Shuttle:
  1. Set up a Google Cloud Platform (GCP) project.
  2. Create a service account for the project, and generate a JSON file with your key pair.
  3. Enable the required APIs for the project.
  4. Enable the project service account.
  5. Request quota increase from Google Drive to reduce rate limiting.
Set up the Google Cloud Platform project
  1. Go to your Google Cloud Platform dashboard page. Navigate to your projects using the dropdown menu on the left of the search bar.
    Google defaults to your last project.
  2. If you don’t have a project, click New Project.
  3. Add your Project name, Project ID, Organization, and Location.
  4. Click Create to continue.
    If you already have a project, editing your Project ID is optional and not recommended.
  5. Open the Google Cloud Platform menu and navigate to IAM & Admin.
  6. Click on Service Accounts in the pop up.
  7. On the Service accounts page, click + Create Service Account.
  8. Add and confirm your service account information, then click Create and Continue. Click Done to return to the Service accounts page.
    Granting project access and user access options are optional.
  9. On the Service accounts page, select the new service account from the previous step. Click the three dot icon in the Actions column. Click Manage keys.
  10. In the Keys tab, click Add Key. Then, click Create new key in the drop down menu.
  11. The prompt gives you two options for downloading a file with the private key. Select the JSON key type. Click Create to download a JSON file to your device.
  12. Save this file in a secure location. It is required for next steps.
  13. Go to API & Services > Enabled APIs & services on the left from the pop up menu.
  14. On the APIs & Services page, click + Enable APIs and Services.
  15. On the API Library page, use the search bar to find the Admin SDK and Google Drive API to add. Click the appropriate result to continue to the next page.
  16. When adding the APIs, click Enable. This brings you to the specific API page. Navigate back to the API Library by clicking API/Service Details above the API title and icon.
  17. Repeat Steps 15 and 16 for the Google Drive API.
Adjust Google Admin settings
  1. Go to your Google Admin page. Scroll down and click Security.
  2. At the Security page, scroll down and click API controls.
  3. At the API controls page, scroll down to Domain wide delegation. Click Manage Domain Wide Delegation.
  4. On the Domain-wide Delegation page, click Add New in the API clients table for the Add a new client ID prompt.
  5. Open the JSON file you have saved before. Copy the Client ID value from the file. Paste the value in the Client ID field in the prompt.
  6. In the OAuth scopes (comma-delimited) field, paste the string in the field from the prompt:
    https://www.googleapis.com/auth/admin.directory.group,https://www.googleapis.com/auth/admin.directory.user,https://www.googleapis.com/auth/drive
    Click Authorize to continue.
Google Cloud Platform quotas
  1. Go to your Google Cloud Platform dashboard page. Use the menu to go to IAM & Admin > Quotas.
  2. At the Quotas page, use the search bar next to Filter in the table. Search for Google Drive API. Select the Google Drive API by clicking the box.
  3. Click Edit Quotas.
  4. At the prompt, update the values for the Google Drive API with the following info.To edit the values, your project must be linked to a billing account. Click Submit Request.
    • Queries per 100 seconds: 100000
    • Queries per 100 seconds per user: 20000
Source analysis
Running an Analysis job helps you understand your source data at a more comprehensive level. The analysis report includes information on data type, size, age, and permissions. As a result, it is easier to divide a large and complex job into smaller manageable pieces to plan which departments or sections to migrate first, as well as to come up with a reasonable approach to migrate your users and their data. This way, large projects can finish quicker, cost-effectively, with fewer conflicts, and more efficient delta runs. The following instructions guide you through the process of setting up your source system and analyzing the files and folders in the origin location.
Configuring a Google Drive source
  1. On Box Shuttle home page, click + to create a new job.
  2. Click Analyze Data.
  3. Under Configure a new system, click the G-Drive tile.
  4. Click Log in to Google Drive.
  5. Add the administrator email.
  6. Provide access to G-Drive with credentials from your JSON file. Click Choose file to open the file explorer.
  7. Select the JSON file you have saved during Google Cloud Platform configuration and click Open.
Running an analysis
Once you have your Google Drive source configured, you can begin to run jobs.
  1. Click the + icon to create a new job.
  3. Under Systems that you configured before select the Google Drive source.
  4. Authenticate and click Continue.
  5. Under Filters, create a filter to include or exclude files. Use + to add a filter or the trash bin icon to remove an existing one. Click Continue to proceed.
  6. On the Select file locations page, choose the source files to analyze.
    • Hover over the row to reveal a folder explorer icon . Use it to browse through your account and add or exclude specific files or folders.
    • The icon allows you to search for the accounts to add.
    • The icon allows you to hide unchecked items or show all.
  7. Click Done to continue.
  8. View the configuration summary.
    • Schedule sets a specific date and time in the future for the Migrate Data job to run. This option also allows for adding the job to the queue.
    • Rename lets you change the name of the job.
    • Click Analyze to start the job. It may take some time to complete.
    • The upper-right corner shows current actions and updates.
    • View Results displays details of the job.
    • Stop ends the job before it is complete.
    • When the analysis is complete, the page displays statistics in a table. Clicking Done redirects you to the home page.
Reviewing analysis results
The analysis results provide details of your source system. You can filter, sort, and export your data.
  1. To check the results go to the home page and click the job you want to examine.
  2. Click View Results to see the details of your analysis.
    • The top overview section provides details about the job and analyzed files.
    • Analysis Statistics displays a chart with results.
      • Use to narrow down the results.
      • Use the buttons below the table to modify the presentation.
    • Analysis Results provides you with the following options:
      • See Results in Table displays a detailed table with the results. Use the Filter to narrow down the data and the “A…” column to change the way longer names are displayed. You can also export the table.
      • Export in XLSX creates a downloadable file.
    • Job History shows the job runs log.
Data-only migration
The following instructions allow you to migrate your data to a single location on the target without migrating permissions.
Running a data-only migration
  1. On the home page, click + to create a new job.
  2. Click Migrate Data. The icon expands to display two options.
    • Migrate Data is checked by default. This job moves data from one location to another.
    • Migrate Permissions allows you to migrate data along with permission settings.
  3. Select Migrate Data.
  4. Under Choose source system, click the configured Google Drive system. Confirm the account information, authenticate, and click Continue.
  5. Under Choose target system, select the Box account as the destination.
    • If a Box system isn’t already configured, select Box under Configure a new system.
    • Enter your Box account credentials and click Authorize.
    • Review the permissions for Box Shuttle and click Grant access to Box.
    • If you’ve already configured an account, confirm the account information and authentication and click Continue.
  6. The next section prompts you to configure migrating file versions. Select Migrate current version only or Migrate all versions to continue.
    If you want to migrate all versions, you must migrate them in order, starting with version 1. If you choose the current version, you cannot migrate previous ones later.
  7. Under Filters, create a filter to include or exclude files. Use + to add a filter or the trash bin icon to remove an existing one. Click Continue to proceed.
  8. Under Select and map file locations, choose the source file locations and accounts to migrate. When you select a source file location, the choose target location box appears. Use the folder explorer to select the target file location.
    • The icon allows you to look for specific accounts to add.
    • The icon allows you to switch between Hide unchecked and Show all items.
    • Use the Default folder button to specify the default parent folder.
      • The + Create a new folder button allows you to add a new folder.
      • The Root folder button sends your data to the root (/) of the designated Box target directory.
  9. Click Done to continue.
  10. The configuration summary contains the following sections:
    • actions you can perform
    • ownership and permission
    • mirror deletions that, if selected, deletes the files that are on the target but not on the source.
    Do not enable the mirror deletions option without understanding how it deletes data in the target location.
    • source system
    • items to migrate
    • target system details
  11. You can now run a Simulation that serves as a quality check for your data migration projects. For details, see Simulation and transfer.
Migrating permissions in data-only jobs
If you run a data-only job, you must manually add permissions to the data once it lands in Box. This action restores previously available access in Google Drive. Consider migrating permissions and data together. See Data migration including permissions for instructions.
This type of data migration transfers not only data, but also ownership rights and permissions from one location to another. This type of migration job is suitable for comprehensive management of files, accounts, and privileges throughout the entire data migration process.
Permission conflicts
When transferring data from Google Drive to Box, the Migrate Permissions job determines whether ownership or permissions are compatible between the two. If any permission conflicts occur between source and target, Box Shuttle provides you with the following options to choose from:
Expand permissionsAdds permissions to child folders or files if they have fewer permissions than a parent.
Restrict permissionsRemoves permissions from the parent folder if a child has fewer permissions than the parent.
Skip files that have conflictsThese folders or files are not transferred in the data migration because they have reduced permissions relative to a parent. They display as filtered in results.
Running a migration with permissions
These instructions will guide you through setting up and running a job that migrates data along with permissions.
  1. On the home page, click the + icon to create a new job.
  2. Click Migrate Data. The icon expands and displays two migration options. Select Migrate Permissions and click Continue.
  3. Under Choose source system, click the already configured Google Drive system. Confirm the account information, authenticate, and click Continue.
  4. Under Choose target system, select the Box account as the destination. Confirm the account information, authenticate, and click Continue.
  5. Select your file version migration: Migrate current version only or Migrate all versions.
    If you want to migrate previous versions, you must include them all. Migrations with the current version configuration do not include previous versions, and they cannot be migrated later on.
  6. Under Filters, create a filter to include or exclude files. Use + to add a filter or the trash bin icon to remove an existing one. Click Continue to proceed.
  7. At this point, you can choose how to resolve permission conflicts during the data transfer process. Select the option appropriate for your data migration job. See Permission Conflicts for details.
  8. Under Select and map file locations, choose the source file locations and accounts to migrate. When selecting items, the choose target location button displays the available accounts in the target system for the respective selection.
    To migrate a Shared Drive, select a specific Shared Drive folder from the enumerated list of personal accounts and Shared Drives. The admin user applied to the Google Drive connector must have manager access for Shared Drive folders that will be migrated.
    Sites, document libraries, and directories selected are all written to Box as directories.
  9. The Migrate Permissions job examines the source to ensure source items map correctly from the source to the target.
    • Click Examine to continue with the job.
    • Click Cancel to return to the Select and map file locations page.
  10. When the examination job has finished, click Done to continue.
    • If Box Shuttle finds errors examining the source, see the conflicts by clicking View Errors. You can also download the full list of paths to get a .CSV file for your reference. Review the list of errors for guidance on how to resolve them.
    • Click Re-examine paths to run the examination once again if you have made any changes. Click Skip paths and continue to omit the file paths and leave.
  11. When the examination is complete, you return to the Select and Map Users and Groups page. View the list of source users and groups to map to target users and groups. Box Shuttle automatically matches identical users and groups. Click Continue to proceed.
    All displayed accounts must be mapped or deselected (marked as skipped) before you can continue.
    • The mapped source users are the data owners whose accounts you selected for transfer. In addition, Box automatically matches identical collaborators from the source to the target.
    • The unmapped source users and groups are collaborators for one or more items in the selected source accounts for transfer.
      • To map the source user/group to a target account, click the respective choose target user on the right. The job displays a list of the valid users or groups to which you can map the source collaborator.
      • To skip the transfer, deselect the checkbox next to a given user or group’s name.
    Do not deselect source users whose accounts were already selected for transfer (data owners). Deselecting a data owner removes their data from transfer.
  12. The next step is processing to scan target users and groups. Processing confirms the owner’s and collaborators’ permissions, paths on the target, and automatically matches according to best possible fit. Click Process to continue and Done when complete.
  13. The last step is the job summary page. It includes information about:
    • Mirror deletions checkbox that, if enabled, allows Shuttle to delete the files that are on the target but not on the source. Do not enable Mirror Deletions without understanding how it affects the target data. Always run and review simulation results when using Mirror Deletions.
    • Source and target system
    • Option to choose the file version to migrate
    • Option you chose for solving migration issues
    • Path and subject mappings
    • Run Simulation performs an estimation on how this job will perform on a transfer run with its current configuration. When the simulation finishes, view the results for details on job performance. These reports include target path configurations as well as possible errors.
    • Transfer immediately starts the data migration.
      Running a Simulation before starting a transfer is highly recommended.
    • Schedule sets a specific date and time in the future for the Migrate Data job to run. This option also allows for scheduling the job behind the queue of another job running.
  14. Run Simulation continues with a preview test run. When the simulation is complete, click View Results to bring up the simulation summary page. For details, see Running a simulation.
  15. When ready to begin, click Transfer to start the data migration process. Once the job has completed, view the results on the Transfer summary page. For details, see Running a data transfer.
Box Shuttle provides a simulation option at the end of your migration configuration. Simulations allow you to get an estimate on runtime and check for potential issues or errors prior to migrating your data. Run a simulation before performing a transfer for an effective and efficient migration plan. Some simulation incompatibilities for Box include files larger than the maximum size supported and unsupported system files, such as thumbs.db or other similar extensions. Once a simulation is complete, view the summary of the estimated job details similar to an analysis job. Preview the simulation results to make the live transfer a more seamless experience. When you’ve completed either a simulation or a transfer, Box Shuttle provides comprehensive results for your reference. Use the information from the summary page to guide your migration configurations. Simulation results help you solve potential problems in the migration planning before data moves to the new target. After running a transfer, delta syncs allow you to maintain updated migration status with active users over time.
  1. You can run simulations from the job summary page for any Migrate Data job configurations.
  2. Click Run Simulation to perform a trial run of the migration job. As a result, you will get an estimate on how fast the job will run with its current configuration. When the simulation finishes, view the results for more information about potential performance of the Migrate Data job. View reports on target path configuration as well as possible errors. We recommend running a simulation prior to migrating live data.
    • Transfer directly starts the data migration process without a Simulation.
    • Rename lets you change the name of the simulation.
  3. After completing the simulation, click View Results. This page contains an estimation of how much time the data transfer will take with the current configuration. Live data transfer results may differ.
    • Simulation Statistics displays a chart with the results. Use the filter icon to narrow down the results. The buttons under the table allow you to modify the presentation according to your choice.
    • Simulation Results includes the following options:
      • See Results in Table displays a table with the results. Use the Filter to narrow down the data and the “A…” column to change the way longer names are displayed. You can also export the table.
  4. Click Done to return to the home page or Transfer to start the data migration job.
After completing a simulation, you can transfer data from the source to the target location.
  1. Click Transfer to start the migration.
  2. When the job begins, the status updates are available at the summary page. Click Stop transfer to end the migration before it is complete.
  3. After the job is complete, click View results. This page contains statistics and information on how the data transfer performed with the current configuration.
    • Transfer Statistics displays a chart with the results. Use the to narrow down the results. The buttons under the table allow you to modify the presentation according to your choice.
    • Transfer Results includes the following options:
      • Export in XLSX creates a file you can download.
  1. Click Done to return to the home page.
Reviewing job results
When you’ve completed either a simulation or a transfer, Box Shuttle provides comprehensive results for your reference. View the results as a table in the interface or download them directly. Use the information from the summary page to guide your migration configurations.
Reviewing audits and storage
When you’ve completed your project, you can collect data from each job. The results are available as downloadable files for record keeping. At the job’s summary page, you can download and save the files for your reference.
Google Drive migration errors reference
Many Google Drive migration errors relate to Google Drive’s unique characteristics, such as specific metadata properties applied to files, folders and Google docs, duplicated files with the same IDs found in multiple locations throughout the tenant, or rate limiting errors. Sections below cover Google-specific issues and contexts.
Metadata, ownership, and permissions errors
No permission to download a file
This error typically occurs in the following scenario:
  1. A file is shared with a user through a domain link or group.
  2. The user mounts the file on their /My Drive.
  3. The user does not have permission to download the file. This may be due to the ACL for viewer or commenter permissions. Also, the user might not have access to list permissions. As a result, Box Shuttle doesn’t know whether the user has write access to the file.
Failed to export file size
Google Docs and Google Sheets might experience the following export errors: Google Docs: Failed to export file size: Forbidden.
Google Sheets: Failed to export file size: Bad request.
The root cause is the same.
  1. Google file is shared with a user who does not have permission to export it. This frequently happens with Google files that are shared through read-only domain links.
  2. The user mounts that file on their /My Drive.
  3. Box Shuttle tries to export the file. However, Google returns a 403 error and the above message.
The owner of the file has export permission. The owner often has that same file located in their /My Drive directory. In this case, the file can be exported with no permission issues through that account. The Failed to export file size: Forbidden error also occurs when transferring Google Docs from a suspended user namespace.
File not found
These files have two main characteristics.
  • Source Account, or owner of the file, is different from the namespace ID, or namespace in the file location.
  • Google field capabilities_canMoveItemOutOfDrive is set to false.
The namespace user does not have permission to move the file out the current /My Drive location and cannot transfer the file. Remediating the break in ownership may resolve the issue.
User does not have permission to read revisions of a shared file
Similar to File Not Found, the namespace and account users are different. In this case, the Google field capabilities_canReadRevisions is set to false, so the namespace user cannot read the versions of the file.
The authenticated user does not have the required access to a file
This issue may come from several causes. It is a common variant of the User does not have permission to read revisions of this shared file error.
Duplicate files errors
These issues are related to duplicate files in Google Drive,
Shared files are not included
Files and folders on Google Drive can be shared out with other users. These appear in the users Shared with Me drive. However, these items can be mounted in the contributor’s /My Drive location. When the contributor mounts the shared file or folder on their own /My Drive, it exists in two distinct physical locations: the owner’s /My Drive and the contributor’s /My Drive. Box Shuttle transfers a single instance of each item, shares it with the applicable additional users, and filters out any additional instances of that item with the error message Shared files are not included. This eliminates data duplication on the target as well as excess byte transfer charges.
Transferring files that have duplicate names
Two entirely different files with different IDs may exist in the same location. For example, /My Drive/GoogleDoc and /My Drive/GoogleDoc can be in the same namespace, but be completely different files with different content. In this case, the first document is transferred with the original path and the second document is transferred with the file ID appended to the file name. This allows Box Shuttle to sync the two documents correctly.
Rate Limiting errors
Google Drive rate limiting
Google Drive jobs may experience rate limiting, however, your request may be partially or completely denied at Google’s discretion. Box is not responsible for Google’s response. Errors resulting from Rate Limiting, such as ENOTFOUND and ETIMEDOUT, may mean the affected files can transfer when the job is run again. The following items need more requests and may increase the rate limiting incidences.
  • Files and folders with extensive sharing, about 25 or more collaborators per item.
    • The item transfers; however, some or all of the sharing may not be included,
    • The item displays in the transfer report as partial-success because not all sharing is applied.
Many Google Docs migrations and file sharing transfers run without issue. For many issues, the following measures help resolve rate limiting.
  • Run Google Drive jobs after normal business hours, or when users are not accessing Google Drive.
  • If you are running a job with permissions, transfer the data in a data only job on one run, and apply the collaborator permissions in a separate job.
  • In the event that you do hit a quota, you may not see any progress on your job for several hours, but that does not mean the job is not active. Shuttle will regularly check on whether the quota has expired, and resume transfer when it does. So you are better off just letting the job continue to run even if the transfer rate flatlines.
  • If your jobs appear to have rate limiting with errors or high retry rates, attempt to divide the job into smaller jobs.
Several types of rate limit errors occur in Google Drive. Most affected files and their permissions transfer on re-run. Situations where Google Docs have extensive commenters may require a third attempt. These are not permanent errors and often resolve through repeated attempts.
Access denied
This error in most cases is a rate limiting error. With Google rate limits, 403 errors are returned instead of a 429 error. These errors frequently resolve on re-run when caused by rate limiting.
Export errors
Failed to export file size: File too large
The exporting API provided by Google supports a max size of 10MB for the exported file. Google Docs greater than this export size generate an error. These must be divided into smaller files to export.
File format cannot be migrated
Google Docs, Sheets, Slides, Draw, and other Google apps can be exported. Google Forms, Maps and other apps cannot be migrated and are filtered out.
Internal server error
Some files may experience Internal Server errors on export - especially Google Sites. Confirm if a downloadable file exports and experiences an error. Many Internal Server errors are persistent. These files cannot be exported and are not transferable.
Access errors
No support for the Google Drive app
The user may not have the Google Drive app enabled for their account. Confirm the user’s app listing at admin.google.com. If the Google Drive app is not enabled, they do not have any storage space enabled. In addition, Box Shuttle does not support external owners or collaborators.
Most users with the drive disabled have never activated it. Box Shuttle cannot access the data if the drive is not activated. Data may still be available and transferable if the drive is reactivated.
