# Unsyncing a Folder
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "has_image , User , End User , Box Sync , Mac , Unsync , Article , New , Product Utilization , Instruction"}} />
  **Note:**
  End of Life (EOL) has been announced for Box Sync effective December 2026. For more information visit the [official announcement page.](/en/announcements/box-sync/announcing-end-of-life-for-box-sync)
If you have a Box folder marked to Sync to your desktop but would no longer want it to be Synced, there are a number of ways to remove that folder. Choose one of the options below to **Unsync** your desired Box folder.
**Method 1:**
1. Highlight the folder
2. Select the **Details** tab on the right
3. Toggle the **Sync to Desktop** option
  <img src="https://mintcdn.com/product-docs/xuuPWgNpL6dP84bD/images/box-sync/screen-shot-2018-03-26-at-3-44-53-pm.png?fit=max&auto=format&n=xuuPWgNpL6dP84bD&q=85&s=702a68ca1cb52ad89c0b072134c48b1d" alt="Screen Shot 2018-03-26 at 3.44.53 PM.png" width="997" height="199" data-path="images/box-sync/screen-shot-2018-03-26-at-3-44-53-pm.png" />
**Method 2:**
1. Select **More Options** button for the folder
2. Hover over **More Actions**
3. Select **Unsync**
  <img src="https://mintcdn.com/product-docs/xuuPWgNpL6dP84bD/images/box-sync/screen-shot-2018-03-26-at-3-47-43-pm.png?fit=max&auto=format&n=xuuPWgNpL6dP84bD&q=85&s=dc7dbb71aa83b31aa59fda847b213c1f" alt="Screen Shot 2018-03-26 at 3.47.43 PM.png" width="999" height="347" data-path="images/box-sync/screen-shot-2018-03-26-at-3-47-43-pm.png" />
**Method 3:**
1. Select **Synced** menu
2. Select **More Options** button for the folder
3. Select **Unsync this Item**
  <img src="https://mintcdn.com/product-docs/xuuPWgNpL6dP84bD/images/box-sync/synced-folder-unsync-this-item.png?fit=max&auto=format&n=xuuPWgNpL6dP84bD&q=85&s=19b3e640b61af3b70ba19c67f3f3432d" alt="Synced folder - unsync this item.png" width="901" height="190" data-path="images/box-sync/synced-folder-unsync-this-item.png" />
