# Using Ready-Sign Links
    display: "inline-block",
    verticalAlign: "middle",
    height: height,
    width: "auto",
    margin: "0"
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "End User , Box Sign , Article , New , Product Utilization , Instruction"}} />
Box's ready-sign link feature allows you to create fillable, signable templates accessible through a shareable hyperlink or embedded on a website, enabling multiple users to easily complete signature requests. The template should need meet certain requirements to be leveraged as a ready-sign link.
  <iframe className="w-full aspect-video rounded-xl" src="https://players.brightcove.net/6291496955001/VkP5RdZVu_default/index.html?videoId=6370298677112" title="Video player" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowFullScreen />
Use this link when you want to post a signature request on a public form — such as an email, social media post, or web page — without knowing who the signers will be. Example use cases include:
* Waivers or release forms
* Applications
* Enrollment forms
**Important:** Ready-sign links do not currently support multi-factor authentication or other signer verification features.
When a recipient uses the link to access the signature request, Box prompts this recipient to provide an email address and sends this recipient an email notification with a unique access code. The recipient can then view the signature request in one of the following ways:
* Use the unique access code.
* Click the **Resume Signing** option in the email.
  **Note:** The ready-sign link feature is limited to **Enterprise plus and Enterprise Advance** customers and not available to Box Verified Enterprises. To learn more about Box Verified Enterprises, click [here](https://support.box.com/hc/en-us/articles/4401823156883).
## Configuration at Admin level
**As a Box Admin, configure a ready-sign link:**
1. From the **Admin Console**, go to **Enterprise Settings** -> **Box Sign**
2. In the **Box Sign** tab, go to **User Permissions,** select **Edit Configuration** under the **Ready-Sign Links** section
3. Within the **Configure Ready-Sign Links menu**, you can:
   * Disable for all managed users
   * Enable for all managed users
   * Enable for select users and groups
   * Enable for everyone except select users and groups
  <img src="https://mintcdn.com/product-docs/NoMCwVPT-KC7a0Gv/images/box-sign/42412807288723.png?fit=max&auto=format&n=NoMCwVPT-KC7a0Gv&q=85&s=322d8641204cbf56c5c8d568482f31cc" alt="" style={{ width: "250px", maxWidth: "100%" }} width="1600" height="1000" data-path="images/box-sign/42412807288723.png" />
Additionally, you can configure the **Email validation for the ready-sign link initiator,** where you can enable or disable this additional validation for managed users or for selected ones.
The **Email validation for the ready-sign link initiator** is an extra step to verify the first or single recipient before they start the signature request. As the Box admin, you can configure the following settings in the Admin Console:
* **Enable email validation** (default):\
  Ensures that all ready-sign links created within your Box enterprise require email validation, which means that **the first** (or only) recipient will receive an email **before** gaining access to the signature request to complete it.
* **Disable email validation**\
  Skips the email validation/access code requirement for any ready-sign links created within your Box enterprise.
* **Allow ability to disable email validation**\
  Provides options to allow for senders to control this feature configuration at a user level:
  * **All users** (default) – All managed users will be able to toggle the **Require email validation** option off or on for each ready-sign link created in the ready-sign **l**ink settings.
  * **Select users and groups** – Select users and groups will be able to control email validation in the ready-sign link settings.
  * **All users except for selected ones** – Identified users and groups will not be able to control this feature in the ready-sign link settings (i.e. The **Require email validation** option will be disabled for them).
  <img src="https://mintcdn.com/product-docs/NoMCwVPT-KC7a0Gv/images/box-sign/42412823223571.png?fit=max&auto=format&n=NoMCwVPT-KC7a0Gv&q=85&s=b4a76e3c020eeccc2f52ef3183b7b69e" alt="" style={{ width: "250px", maxWidth: "100%" }} width="1600" height="1040" data-path="images/box-sign/42412823223571.png" />
## Creating and configuring ready-sign links
Before creating ready-sign links, you will need editor permissions prior to selecting a template in addition to the following template requirements:
* Template has recipient placeholders
* Template has ‘Signer’ recipient role configured
* Template does not have recipient security settings applied
  **Note:** CFR Part 11 signature requests are not compatible with the ready-sign link feature.
**To create a ready-sign link:**
1. From your Box account, go to **Sign** -> then **Template**
2. Select the template to use
3. Click the ellipsis <InlineImage src="/images/box-sign/42412807292051.png" alt="" /> and then select **Ready-Sign Link**
4. Toggle on **Link is active**.
  <img src="https://mintcdn.com/product-docs/NoMCwVPT-KC7a0Gv/images/box-sign/42412807295123.png?fit=max&auto=format&n=NoMCwVPT-KC7a0Gv&q=85&s=4a7222128adfd483aba3fa9fd1562acf" alt="" style={{ width: "250px", maxWidth: "100%" }} width="1600" height="1000" data-path="images/box-sign/42412807295123.png" />
  <img src="https://mintcdn.com/product-docs/NoMCwVPT-KC7a0Gv/images/box-sign/42412823256467.png?fit=max&auto=format&n=NoMCwVPT-KC7a0Gv&q=85&s=40ae16b0902c2380db4f1bdf17d03f82" alt="" style={{ width: "250px", maxWidth: "100%" }} width="1600" height="1000" data-path="images/box-sign/42412823256467.png" />
**To configure link settings:**
1. Click **Link Settings** within the **ready-sign link** window to modify the following:**Name**
   * **Instructions**
   * **Save location**
   * **Require email validation** – Dependent on the settings configured by your admin in the Admin Console. **Enabled by default.**
   * **Disable notifications for the template owner** – Dependent on whether you want the creator of the template to receive email notifications on incoming signed signature requests. **Enabled by default.**
2. Click **Save**.
  <img src="https://mintcdn.com/product-docs/NoMCwVPT-KC7a0Gv/images/box-sign/42412823269907.png?fit=max&auto=format&n=NoMCwVPT-KC7a0Gv&q=85&s=c7f90d2f844d5b937a636330e34f983a" alt="" style={{ width: "250px", maxWidth: "100%" }} width="920" height="1506" data-path="images/box-sign/42412823269907.png" />
Once you have configured the link, click **Copy** to use the link.
## Signing and managing ready-sign links
Once a recipient initiates the ready-sign link, they will be prompted to provide their email address and, if applicable, additional email addresses for subsequent recipients.
  <img src="https://mintcdn.com/product-docs/NoMCwVPT-KC7a0Gv/images/box-sign/42412823271187.png?fit=max&auto=format&n=NoMCwVPT-KC7a0Gv&q=85&s=0e61029b6d1e1bc5e107c4a2d7c32898" alt="" style={{ width: "250px", maxWidth: "100%" }} width="1232" height="840" data-path="images/box-sign/42412823271187.png" />
If the **Require email validation** setting was enabled, then the initiating recipient receives an email with an access code to access the request. Alternatively the recipient can click **Resume Signing** in the same email to gain access to the request. No validation is required if the setting is disabled.
  <img src="https://mintcdn.com/product-docs/NoMCwVPT-KC7a0Gv/images/box-sign/42412807316755.png?fit=max&auto=format&n=NoMCwVPT-KC7a0Gv&q=85&s=a6cf36a53090471a653a9dfe302b1e1c" alt="" style={{ width: "250px", maxWidth: "100%" }} width="1232" height="592" data-path="images/box-sign/42412807316755.png" />
All other recipients will receive an email notification to access and complete the signature request.
If you are the owner of a Box Sign template used in a ready-sign link, Box enables you to see the status of those signature requests.
**To see the status of signature requests initiated via ready-sign links with a template you own:**
1. From your Box account, go to **Sign** -> then **Sent Requests**
   * Box displays a list of sent signature requests that use your template, including those sent as Ready-Sign links.
2. At the top of the signature request list, you can apply filters to sort the requests:
   * **Method** to look for ready-sign links, and
   * **Status** to check the progress of the request
  <img src="https://mintcdn.com/product-docs/NoMCwVPT-KC7a0Gv/images/box-sign/42412823275283.png?fit=max&auto=format&n=NoMCwVPT-KC7a0Gv&q=85&s=902342453b383ca56b6c2b53f4273959" alt="" style={{ width: "250px", maxWidth: "100%" }} width="1600" height="1000" data-path="images/box-sign/42412823275283.png" />
