# Enforcing recipient authentication methods
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "Admin , End User , Box Sign , Security and compliance , Article , New , Instruction , P2"}} />
Admins can enforce a required recipient authentication method for the users and groups they choose. When an authentication method is enforced, senders must use that method for every recipient on a signature request. This helps enterprises maintain consistent security and compliance across the organization.
## Overview
Admins can configure recipient authentication enforcement in the **Additional Recipient Authentication** section of the **Box Sign** tab in the Admin Console. From the **Required Recipient Authentication** drop-down list, admins can choose the specific method to enforce. The list includes the following options:
* **Box Login** – recipients log in to their Box account before signing.
* **SMS Authentication** – recipients verify their identity through an SMS text message.
* **CAC/PIV Card** – recipients authenticate with a Common Access Card (CAC) or Personal Identity Verification (PIV) smartcard. Available only with the Box Sign CAC/PIV Add-On Pack.
For details about each method, see [Additional recipient authentication](/en/box-sign/sending-a-document-for-signature/additional-recipient-authentication).
Admins can enforce an authentication method for all users in your enterprise or for a selected list of users and groups.
  <img src="https://mintcdn.com/product-docs/oJ2JV5OGV33_riLc/images/box-sign/box-sign-required-recipient-authentication.png?fit=max&auto=format&n=oJ2JV5OGV33_riLc&q=85&s=8d250240682c02e43a10f90caf038915" alt="Admin Console Box Sign tab with the Additional Recipient Authentication section and the Required Recipient Authentication drop-down list open, showing Box Login, SMS Authentication, and CAC/PIV Card options." width="2880" height="1800" data-path="images/box-sign/box-sign-required-recipient-authentication.png" />
  This setting does not apply to 21 CFR Part 11 requests. Those requests continue to use Box Login as the authentication method. For more information, see [21 CFR Part 11 compliance support](/en/box-sign/sending-a-document-for-signature/21-cfr-part-11-compliance-support).
  Enforcement also applies only to signature requests created in Box Sign. It does not apply to requests created through [Box Automate](/en/box-automate/about-box-automate), [Box Relay](/en/box-relay/about-relay/introducing-box-relay), or the Box Sign Salesforce integration.
## Requirements for CAC/PIV
CAC/PIV smartcard authentication is available on Enterprise Plus and Enterprise Advanced plans only and requires the Box Sign CAC/PIV Add-On Pack. For more information, see [CAC/PIV e-signature authentication](/en/box-sign/box-sign-for-admins/cacpiv-e-signature-authentication).
To enforce CAC/PIV for a user, both of the following must be true:
* The user has permissions enabled for CAC/PIV.
* The user has permissions enabled for Required Recipient Authentication.
<Warning>
  If you enable enforcement but a user does not have the matching CAC/PIV permission, the enforcement does not apply to that user. The Admin Console indicates this condition so you can correct the user's permissions.
</Warning>
## Enforcing an authentication method
To enforce a recipient authentication method:
1. In the Admin Console, go to **Enterprise Settings** > **Box Sign**.
2. In the **Additional Recipient Authentication** section, next to **Required Recipient Authentication**, select **Edit Configuration**.
3. Select whether the enforcement applies to all users or to a specific list of selected users and groups.
4. From the **Required Recipient Authentication** drop-down list, select the method you want to enforce.
5. Select **Save**.
## Sender experience
When a recipient authentication method is selected for a sender, that sender's experience changes as follows:
* Box automatically applies the enforced authentication method to every recipient in a new signature request.
* The sender cannot send the request until the requirements for the enforced authentication method are complete.
### Revising a request
Requests sent before you enforce an authentication method are not affected. When modifying an in-flight signature request, users cannot change the authentication method to one that the admin setting does not enforce. If they attempt to do so, a red banner and a validation error indicate that the sender must use the enforced authentication method.
The same behavior applies to shared requests. For more information, see [Sharing signature requests](/en/box-sign/sign-document-management/sharing-signature-requests).
## Templates
### Creating a template
When an authentication method is enforced, template creation changes as follows:
* Box automatically sets each placeholder and recipient to the enforced method.
* When a creator edits a template, Box displays a validation error if the creator tries to save the template with a method other than the enforced one.
When a creator saves a document as a template:
* **Unlocked template** – the template automatically defaults to the enforced method.
* **Locked template** – the creator cannot save the document as a template if the recipient fields are locked.
### Using a template
Authentication methods configured within a template can be modified unless the template creator locks the template. When a template's method differs from the one you enforce, the template user's experience depends on whether the template is locked:
* **Unlocked template** – if a recipient does not have an authentication method configured within the template, Box automatically sets it to the enforced method and informs the sender. If a recipient is set to any other method, the sender receives an error when they select **Send**, indicating that they must change the method to the enforced one.
* **Locked template** – the sender is blocked from using a template if it contains an authentication method that they are not permitted to use.
## Batch send
When a template is set to the enforced authentication method and a user runs a batch send signature request with it, the CSV file uploaded to start the batch send request must include the details for that method. Box displays a validation error if those details are missing or if a value does not match the enforced method. For more information, see [Using batch send templates](/en/box-sign/templates/using-batch-send-templates).
<Warning>
  If a sender adds themselves as a signer on a batch send request, Box does not apply the enforced authentication method to that sender.
</Warning>
## Ready-sign links
Ready-sign links do not support additional recipient authentication methods. If a template is set to an enforced authentication method, you cannot generate a ready-sign link from that template. For more information, see [Using ready-sign links](/en/box-sign/sending-a-document-for-signature/using-ready-sign-links).
## API
When you set the authentication method through the API, Box validates the method against the sender's permissions. If the sender belongs to an enterprise with an enforced authentication method and attempts to select a different authentication method, Box returns a validation error.
