# Configuring Signature Settings
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "has_image , Admin , Box Sign , Overview , Article , Product Utilization , Established"}} />
## Overview
As an admin, you can configure whether recipients will see the signature frame with a Box Sign logo and signature request ID when applying their signature to a signature request. Additionally, admins can also configure the option to automatically apply a date and timestamp based on the sender’s time zone within the signature frame when recipients apply their signature, initials, and or stamp to a signature request.
  **Note:**
  Enabling these settings will not affect CFR Part 11 requests.
<Warning>
  **Limitation:**
  Sign Myself, Batch Send, and Ready Sign Links do not support these signature settings. If you send these types of requests with these settings enabled, the signature frame and date and timestamp features are not applied.
</Warning>
## Signature Frame
Admins can toggle the **Enable signature frame** setting ‘on’ in order to automatically apply the signature frame complete with the Box Sign logo and signature request ID for all signature requests sent from their EID. With this setting disabled, recipients will only see their signature without the signature frame when applying their signature to a signature request. This setting is enabled by default.
**To enable or disable the signature frame:**
1. Navigate to the **Admin Console** and select **Enterprise Settings**.
2. Click the **Box Sign** tab.
3. Within the **Signature Settings**, toggle **Enable signature frame** on or off:
   * **On**: Displays the signature frame with the Box Sign logo and sign ID.
   * **Off**: Displays the signature only without the signature frame.
4. Click **Save**.
**With Frame**
  <img src="https://mintcdn.com/product-docs/4cKZyugvOe74tcd2/images/box-sign/44863654060435.png?fit=max&auto=format&n=4cKZyugvOe74tcd2&q=85&s=597eb28f482d73dbcf9b2f4a0484ee8f" alt="" width="920" height="404" data-path="images/box-sign/44863654060435.png" />
**Without Frame**
  <img src="https://mintcdn.com/product-docs/4cKZyugvOe74tcd2/images/box-sign/44863679694227.png?fit=max&auto=format&n=4cKZyugvOe74tcd2&q=85&s=2def10ef6347943652c7a0763e6e9c2a" alt="" width="528" height="136" data-path="images/box-sign/44863679694227.png" />
  **Note:**
  Signature frame needs to be enabled to add a date and timestamp.
## Date and Timestamp
When the **‘Enable signature frame’** setting is enabled, admins can configure the ability to automatically apply the date and timestamp for recipients anytime they apply their signature to a signature request. The displayed date and time reflect the sender’s time zone the moment the signer adopts their signature. To ensure clarity, these placeholders will have minimum sizing requirements applied once this feature is enabled to ensure legibility. The date and timestamp setting applies to signature, initials, and stamp fields.
The date and timestamp will be set out in the 24 hour time format as shown below:
**\[Date Month Year HH:MM:SS.mmm]**
**To enable or disable date and timestamp:**
1. Navigate to the **Admin Console** and select **Enterprise Settings.**
3. Within the Signature Settings, toggle **Add date and timestamp on the signature field** ‘on’ or ‘off’ depending on your preferences.
4. Click **Save**.
  **Note:**
  Enabling Date and Timestamp will not only reflect sender timezone in the signature, initials and stamps fields, as applicable but also in the date signed field.
## Signature Log
Depending on the enablement of the date and timestamp on the signature field, the following details in the Signature Log will be captured:
1. **Signing Time:** This field will reflect the date and timestamp at the time when a signer adopts a signature for the relevant signature field placeholder. This date and timestamp will be based on the timezone of the sender of the signature request.
2. **Document Signed**: This field will reflect the date and timestamp at the time when a signer selects “Sign & Finish” to complete the signing process for the signature request for that signer. This date and timestamp will be based on the timezone of the sender of the signature request.
