# Dropbox for Business
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "Admin , New , Box Shuttle"}} />
  This article is about Box Shuttle in the Admin Console. If you’re using legacy Box Shuttle, a standalone tool, see [legacy migration guides](/en/box-shuttle/box-shuttle-legacy).
## Set up Dropbox for Business as the source system
1. Provide a unique name for the job.
2. Select **Dropbox**.
3. Follow the on-screen instructions to connect Dropbox for Business
   1. Log in with your admin credentials.
   2. Authorize Box Shuttle to access your data.
  <img src="https://mintcdn.com/product-docs/6Q7nCk1JXzHqPpg6/images/box-shuttle/dropbox-setup-dialog-admin-login.png?fit=max&auto=format&n=6Q7nCk1JXzHqPpg6&q=85&s=0e7351af371a2b7e48a84bfd04c7a1c4" alt="Dropbox setup dialog with admin login instructions, Delegate Log In link, and Log In button." width="835" height="411" data-path="images/box-shuttle/dropbox-setup-dialog-admin-login.png" />
*Box Shuttle does not support migrating from Personal Dropbox accounts, only from Business accounts.*
## Dropbox for Business migration specifics
### Common errors and troubleshooting
The following table describes common migration errors and their solutions.
| **Error** | **Cause** | **Solution** |
| You aren’t a member of this shared folder. | The OAuth user has access to the top level of the team folder, but their permissions were removed from a subfolder. | Add the OAuth user as an edit-level collaborator to the subfolder in the Dropbox admin console under **Content**. The affected subfolder transfers when you re-run the job. |
### Additional considerations
Dropbox Paper files are **not** transferred during migration.
