# Viewing Box Shuttle job report charts
> [!NOTE]
> This article is about Box Shuttle in the Admin Console. If you’re using legacy Box Shuttle, a standalone tool, see [legacy migration guides](https://docs.box.com/en/box-shuttle/box-shuttle-legacy).
The **Charts** tab on the Job Report page shows the data Shuttle collects during a job as charts. Use the charts to understand the content you plan to migrate, monitor the performance of a running job, or review what was migrated, without leaving the job report.
## Before you start
* Charts are available for every job type: analysis, simulation, and transfer. Some charts apply only to transfer jobs. For details, see [Available charts](#available-charts).
* Charts are available as soon as a new job run starts. They may not show meaningful results until the job collects some data.
* Charts use the same data as the **Report** and **Users** tabs. Anyone who can open a job report can view its charts.
## View charts
1. Open the job report for the job run you want to review.
2. Select the **Charts** tab.
By default, Shuttle displays the charts most relevant to the job type:
| Job type | Charts displayed by default |
| Analysis | All File Size |
| Simulation | All File Size |
| Transfer | Files Transmitted, Bytes Transmitted, and Transfer Rates |
Where applicable, the charts reflect the filters you selected for the report.
## Add or remove charts
1. On the **Charts** tab, select the settings icon (![Gear-shaped settings icon](https://docs.box.com/images/box-shuttle/shuttle-charts-settings-icon.png)).
2. In the sidebar, select the charts you want to add, and clear the ones you want to remove. The sidebar groups charts by type, such as **Histogram** and **Grouped**. You must select at least one chart.
When you display multiple charts, Shuttle loads them one at a time. Charts lower on the page may take longer to appear.
## Available charts
Shuttle provides two types of bar charts, histograms and grouped charts, as well as donut charts and line charts.
### Histograms
Histograms show how your files are distributed across a metric, such as file size or age. The horizontal axis divides the metric into even ranges, and the vertical axis shows the number of files in each range.
Charts that start with **All** include every file found in the job. Charts that start with **Transferred** include only files that transferred successfully.
| Chart | What it shows |
| All File Size | The distribution of file sizes for all files |
| Transferred File Size | The distribution of file sizes for files that transferred successfully |
| All Time since file creation | The age of all files, based on their creation date |
| Transferred Time since file creation | The age of files that transferred successfully, based on their creation date |
| All Last Modified | When all files were last modified |
| Transferred Last Modified | When files that transferred successfully were last modified |
| All Last Access | When all files were last accessed |
| Transferred Last Access | When files that transferred successfully were last accessed |
> [!NOTE]
> Only a few source types record when a file was last accessed. Windows is the most common. If your source doesn't record this information, the **Last Access** charts are empty.
### Grouped charts
Grouped charts show the top five items, such as owners or file extensions, with the highest value for the metric. Where applicable, a sixth bar combines all other items. For example, **File Size per Owner** shows the five owners with the largest number of bytes transferred, and the vertical axis shows the total bytes moved for each owner.
| Files per Owner | The number of files each source user owns |
| File Size per Owner | The total size of the files each source user owns |
| Files per Target Account | The number of files for each target Box account |
| File Size per Target Account | The total size of the files for each target Box account |
| Total Size per Extension | The total size of files for each file extension |
| Total Size per Category | The total size of files for each file category, such as documents or images |
### Donut charts
| Files per Extension | The share of files for each file extension |
| Files per Category | The share of files for each file category, such as documents or images |
### Line charts
Line charts are available only for transfer jobs. They show the progress of the migration over time.
| Bytes Transmitted | The amount of data transferred over time |
| Transfer Rates | The transfer speed in files per second (FPS) and bytes per second (BPS) |
| Files Transmitted | The number of files transferred successfully over time |
