# Testing Shield in Trial Mode
    display: "inline-block",
    verticalAlign: "middle",
    height: height,
    width: "auto",
    margin: "0"
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "has_image , Admin , Box Shield , Article , New , Instruction , Rollout , P3"}} />
When certain criteria are met, Box enables prospective Box Shield customers to test Shield capabilities (except for an [information barrier](/en/box-shield/shield-information-barrier/understanding-information-barriers)) during a 30-day trial (also known as proof of concept, or POC). This topic explains how to use the "Shield Trial Mode" feature, which enables you to test Shield's classification-based security controls in your production environment of Box during a trial without impacting the Box experience for the majority of your managed users.
If you're interested in deploying Shield on a trial basis, please contact your account team to request a Shield trial.
Setting up Shield testing in Trial Mode is done in 4 steps:
<Warning>
  **Important**
  Only users within your organization you specifically select to participate in the Shield trial, which you do in [Step 1: Select users for the Shield trial](#step-1-select-users-for-the-shield-trial), will be able to classify items with the classifications you create for the trial, and only for items the user is a owner of.
</Warning>
<h3 id="step-1-select-users-for-the-shield-trial">
</h3>
After Box enables your Shield trial, first determine the Box users in your organization who will test Shield's classification-based access controls. This may be a group of individuals in your IT or Security teams, or a small department or functional team in your organization.
  **Note**
  Only this group of users will be able to view, apply, or modify new classification labels created for the purposes of the trial. The rest of your managed users, will see no change to their Box experience.
  Only the primary admin, not any co-admins, can configure users for Shield trial.
**To configure a list of users for Shield trial:**
1. In the Admin Console's left pane, click **Shield**.
2. In the top of the Shield window, click **Access Policies**.
3. In the top-right corner, click **Configure Trial Users**. Box displays the **Configure Shield Trial**  window.
4. Select one of the following options:
   * **Disable for all managed users**
   * **Enable for all managed users**
   * **Enable for select users**
   * **Enable for everyone except select users**
  **Note**
  Box recommends you select **Enable for select users** to limit the Shield Trial to a small group of users. Type Box users by name or email address. As you type, Box displays names of users you can select (see screenshot below).
    <img src="https://mintcdn.com/product-docs/72o8vyBxKgHlyFAJ/images/box-shield/screen-shot-2020-02-12-at-10-17-00-am.png?fit=max&auto=format&n=72o8vyBxKgHlyFAJ&q=85&s=c611e8fad92e252ceebacd58a09f4363" alt="screen-shot-2020-02-12-at-10-17-00-am-png" width="2532" height="1580" data-path="images/box-shield/screen-shot-2020-02-12-at-10-17-00-am.png" />
5. In the bottom-right corner of the window, click **Save**.
  **Note**
  The managed users who you select here to participate in the Shield trial are the ones who will be affected by Smart Access policies in that they can view, edit, and remove classification labels and will be subject to classification based access policies. (Threat Detection applies to all users automatically if a detection rule is enabled.)
  Users who manage the trial must also be given the co-admin role and must have at least one of the Shield permissions enabled. If they need to set up classification schema, configure access policies, or create threat detection rules, they need both view and edit privileges. If they just need to view classification schema and threat alerts, they need view privileges only. See [Granting And Modifying Co-Admin Permissions](/en/box-admin-tools/managing-box-users-and-admins/managed-users/granting-and-modifying-co-admin-permissions) and [Users & Groups Settings](/en/box-admin-tools/managing-box-users-and-admins/understanding-user-management/users-groups-settings) for details.
### Step 2: Create new classification label(s)
Next, create new classification label(s) ("**trial classifications**") for the purposes of your Shield trial. For instructions on how to create, modify, or delete classification labels, see [Classification Labels](/en/box-shield/shield-classification-labels-and-policies/classification-labels). If you are already using Box classifications in your Box environment, you will still need to **create new classification labels** for the Shield trial purposes - for example, \[TEST CONFIDENTIAL].
### Step 3: Configure Shield Smart Access policies
You can now create Shield Smart Access policies for your new classification labels, which will be enforced for only the group of Shield trial users. Refer to our Using Smart Access article to [create an access policy](/en/box-shield/getting-started-with-box-shield/configuring-shield-access-policies-to-match-industry-best-practices).
### Step 4: Apply classifications and test access policy enforcement
You can now ask your Shield trial users to begin classifying files and folders using the new labels, and test out the access policy enforcement and restrictions.  Shield trial users can apply trial classifications to files or folders that are owned by Shield trial users.
<Warning>
  **Important**
  * Box recommends your Shield trial users apply trial classifications *only to previously unclassified files and folders*. If a Shield trial user applies a trial classification to a previously classified file, non-Shield trial users will not see a classification on the file.
  * Shield trial users will not see the **Classify** option in the Preview mode of files that are not owned by a Shield trial user. The only exception is in the **All files** page, where all users will see the **Classify** option, but a non-trial user will not be able to classify any file. Only users who you enabled for Shield trial will be able to apply a classification label or edit the classification label for a file they own.
</Warning>
## Ending the Shield trial
At the end of your 30-day trial, Shield will be disabled from your production environment. All **trial classification** labels created during the 30-day trial will be permanently deleted, and all files and folders that had a **trial classification** will become unclassified. All other trial data, i.e., access policies, detection rules, alerts, will also be permanently deleted.
  **Note**
  The following features are not available in the Shield trial:
  * Automated classification
  * Microsoft Information Protection integration
  * Information barrier
