# Opening or Searching for Box Notes
    display: "inline-block",
    verticalAlign: "middle",
    height: height,
    width: "auto",
    margin: "0"
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "End User , Box Notes , Users , Search , Open , Article , New , Product Utilization , Instruction"}} />
In the Box Notes web interface, you can open or search for any Box Note that you have access to.
**Opening Box Notes**
1. From your **Files** page, in the lefthand navigation select **Notes** to open your default Box Notes folder.
2. Select the folder icon in the upper left corner of the toolbar.
3. In the window that opens, select the Box Note you would like to open by selecting the bubble beside its name. You can also search for a Box Note using the search bar in the pop-up. Select **Choose** when you have selected a Box Note.
To return to a previously opened Box Note, access it from your [Recents](/en/box-notes/staying-organized-in-box-notes/accessing-recent-box-notes).
**Searching Box Notes**
Box Notes includes a redesigned quick search with improved results to help you find notes faster.
1. Select the search icon in the upper left.
2. Enter your search terms in the search bar that displays. Results update as you type, surfacing the most relevant notes.
3. Select a result to open that note.
