# Box Notes in Box for Android
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "has_image , End User , Box Notes , Users , Share , Article , New , Product Utilization , Instruction , Mobile - Android"}} />
Box Notes can be created and edited in the Box Android app. Box Notes are web-based documents and do not require any additional software. Use Box Notes to create, edit, and share ideas in real-time with your collaborators.
**Creating Box Notes**
To create a new Box Note:
* Navigate to the folder where you'd like to create the new Box Note.
* Tap the **+** icon from the action menu at the bottom of the screen.
* Tap **New Box Note**.
* Name your Box Note, then tap **Create**. The note will open automatically.
**Editing Box Notes**
* Tap the **Edit** icon in the bottom-right to begin typing in your new Box Note.
* Use the **toolbar** at the top of the screen to format text. Apply changes to existing text by highlighting it before selecting a formatting option.
  <img src="https://mintcdn.com/product-docs/w-T_6NPwQG7Ze9eT/images/box-notes/box-for-android-6.png?fit=max&auto=format&n=w-T_6NPwQG7Ze9eT&q=85&s=465ddbc59846a25d56cdf2db3d29b744" alt="box-for-android-6" width="999" height="888" data-path="images/box-notes/box-for-android-6.png" />
* Tap the **Check Mark** in the upper-left once you are done typing to dismiss the keyboard.
* You can leave comments on Box Notes by tapping the **Comment** icon in the upper-right corner.
**Sharing Box Notes**
Tap the **Share Link** icon at the top of the screen, then tap the **Share link enabled** slider to generate a [shared link](/en/box-fundamentals/for-users/collaborating/using-shared-links/creating-shared-links) to your Box Note.
Only collaborators with [access levels](/en/box-fundamentals/for-users/collaborating/collaborating-by-inviting-others/understanding-collaborator-permission-levels) of Editor or Co-owner can make changes to Box Notes. All other collaborators will only have view access. You can choose to send the shared link directly to collaborators via the messaging app of your choice, or copy the link to the clipboard and paste it later.
