# Inserting Emojis and Symbols
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "End User , Box Notes , Article , New , Product Utilization , Instruction"}} />
Box enables you to insert various emojis and symbols into your Box Notes by typing commonly used character combinations.
This feature is available on all supported platforms.
## Using Emojis and Symbols
To insert an emoji or symbol, type in the selected character combination and press **space** key. Box automatically changes the text to an emoji or symbol.
## List of Emojis and Symbols
Consult the table below for a list of available emojis and symbols.
You can also access this list from Box Notes settings menu:
1. Click the **Settings** button in the bottom left corner of Box Notes.
2. Select **Emoji shortcuts** from the list.
| **Name**         | **Symbolic representation** | **Output** |
| Copyright        | (c)                         | ©          |
| Heart            | \<3                         | ❤️         |
| Shrug            | /shrug                      | ¯\_(ツ)\_/¯ |
| Smile            | :)                          | 🙂         |
| Stuck out tongue | :P                          | 😛         |
| Wink             | ;)                          | 😉         |
| Laquo            | \<\<                        | «          |
| Raquo            | >>                          | »          |
| Left Arrow       | \<-                         | ⟵          |
| Multiplication   | 1\*2                        | 1×2        |
| Not Equal        | !=                          | ≠          |
| Half             | 1/2                         | ½          |
| Plus Minus       | +/-                         | ±          |
| Trademark        | (r)                         | ®          |
| Right Arrow      | ->                          | ⟶          |
## Deleting Emojis and Symbols
To remove an emoji or symbol, do one of the following:
* On Mac: Press **Cmd** and **Z** at the same time.
* On Windows: press **Ctrl** and **Z** buttons at the same time.
* Press the **backspace** button to revert an emoji or symbol to text. To remove it completely, keep pressing the **backspace** button until all characters are deleted.
