# Inserting and Formatting Tables in Box Notes
    display: "inline-block",
    verticalAlign: "middle",
    height: height,
    width: "auto",
    margin: "0"
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "has_image , End User , Box Notes , Users , Tables , Article , Product Utilization , Established , Instruction"}} />
## Inserting tables
To insert a table into your Box Note:
* Select the table icon from the top toolbar.
  <img src="https://mintcdn.com/product-docs/AnmsZaFTYelmS6p6/images/box-notes/notes-table-icon.png?fit=max&auto=format&n=AnmsZaFTYelmS6p6&q=85&s=438bdc0a6a7d0109dada73e24be697ea" alt="The top tool bar showing the add table icon." width="510" height="116" data-path="images/box-notes/notes-table-icon.png" />
* Select **+** from the left context menu and select **Table**.
* Type `/` in your note and select **Table** from the slash menu. You can also type `/table` to filter directly to the table option.
  <img src="https://mintcdn.com/product-docs/AnmsZaFTYelmS6p6/images/box-notes/notes-add-table.png?fit=max&auto=format&n=AnmsZaFTYelmS6p6&q=85&s=84cf7135b5b783e97efd2acdaca9343b" alt="The add menu showing the AI and the plus icons." width="132" height="180" data-path="images/box-notes/notes-add-table.png" />
Box then displays the table in your Box Note.  You can now enter text into the table, and format the table to meet your needs.
* If you add rows below a row that has specific justification and then add or paste content in those new rows, the content follows the justification of the row above.
## Inserting tables from outside Box Notes
If you have a table from another source, you can copy that table and paste it into the Box Note. All structural formatting and content, including color of the cells, from the table remain similar after you paste it. You can also copy a table from Box Notes and paste it into another source.
  Structural formatting is lost when pasting between Box notes and Excel desktop. See [Box Notes Limitations](https://support.box.com/hc/en-us/articles/8427168240147) for more information.
## Formatting tables
Box provides two ways for you to format a table.  You can select from a variety of actions in a cell menu, or use the table's grid display to add or remove columns and rows.
When you click a cell:
* Box displays the cell menu icon in the cell's top-right corner.
* Box displays the table in grid display with a shaded border and dots along the top and left sides of the table.
### Using table menus
**Accessing the table menu:**
Click the ellipsis menu  <InlineImage src="/images/announcements/image.png" alt="Box Announcements page with Company Users and Company Admins tabs, Create Announcement button, and draft and live announcements list." /> on the following areas to view specific actions:
* All areas
  * Background Color
  * Clear Cell(s)
* Row, Column, Table
  * Delete item
* Multiple selected items (Drag and hold)
  * Merge items
* Side of row
  * Set row header
  * Duplicate row
  * Merge cells
  * Insert above
  * Insert below
* Top of column
  * Sort Column
    * Ascending
    * Descending
  * Set column header
  * Duplicate column
  * Merge cells
  * Insert left
  * Insert right
* Cell
  * Insert above
  * Insert below
  * Insert left
  * Insert right
  * Delete row
  * Delete column
If you highlight the whole table:
* Background Color
* Distribute column
* Clear Cells
* Delete Table
### Using the table’s grid display
Icons in the table’s grid display enable you to
* Insert a column to the left or right of a selected column
* Remove columns
* Insert a row above or below a selected row
* Remove rows
In contrast to the cell menu, which enables you to insert columns to the right and insert rows below, the table's grid display enables you to insert columns to both left and right, and insert rows both above and below.
**To insert a column via the table’s grid display:**
1. Click a cell where you want to insert the column.  At the top of the table, Box displays a dot above each of the column's borders.
2. To add a column to the left, hover on the dot above the column's left border.  To add a column to the right, hover on the dot above the column's right border.  Box displays a **+** icon.
3. Click **+**.
  <img src="https://mintcdn.com/product-docs/w-T_6NPwQG7Ze9eT/images/box-notes/insert-column.png?fit=max&auto=format&n=w-T_6NPwQG7Ze9eT&q=85&s=b6d42e088455fc01132aec0e4e0b5c18" alt="Insert_Column.png" width="406" height="258" data-path="images/box-notes/insert-column.png" />
**To remove a column via the table’s grid display:**
1. Click the top cell of the column you want to remove.  To select multiple columns, click then drag and release.  Box displays a shaded border along the top of the table.
2. Click the shaded border above the column.  Above the column, Box displays an **x** icon.
3. Click **x**.
  <img src="https://mintcdn.com/product-docs/w-T_6NPwQG7Ze9eT/images/box-notes/delete-column.png?fit=max&auto=format&n=w-T_6NPwQG7Ze9eT&q=85&s=711126b24b402d5f607ff73e2cdfc11a" alt="Delete_Column.png" width="408" height="395" data-path="images/box-notes/delete-column.png" />
**To insert a row via the table’s grid display:**
1. Click a cell in a row where you want to insert a new row.  On the table’s left side, Box displays a dot beside each of the row's borders.
2. To add a row above, hover on the dot beside the row's top border.  To add a row below, hover on the dot beside the row's bottom border.  Box displays a **+** icon.
3. Click **+**.
  <img src="https://mintcdn.com/product-docs/w-T_6NPwQG7Ze9eT/images/box-notes/insert-row.png?fit=max&auto=format&n=w-T_6NPwQG7Ze9eT&q=85&s=833cd655d6f3649b4b45c705b98f53c2" alt="Insert_Row.png" width="578" height="227" data-path="images/box-notes/insert-row.png" />
**To remove a row via the table’s grid display:**
1. Click a cell in the row you want to remove.  To select multiple rows, click then drag and release.  Box displays a shaded border along the left side of the table.
2. Click the shaded border beside the row.  Beside the row, Box displays an **x** icon.
3. Click **x**.
  <img src="https://mintcdn.com/product-docs/w-T_6NPwQG7Ze9eT/images/box-notes/delete-row.png?fit=max&auto=format&n=w-T_6NPwQG7Ze9eT&q=85&s=8bdd32a3735d5b0419a86c102591df60" alt="Delete_Row.png" width="600" height="231" data-path="images/box-notes/delete-row.png" />
**To move a row or column**
1. Hover over the top of the row or column to select it.
2. Drag and drop the row or column above, below, to the right or left of another row or column.
### Adjusting column width
Box enables you to select a column’s border, and then drag the border to the desired width.
Box also enables you to equalize the widths of all columns in a table.
**To adjust the width of a column:**
1. Hover on a column’s border.  Box highlights the border.
2. Click and hold on the highlighted border.
3. Move your mouse left or right, then release.
**To equalize all column widths:**
1. Click in a cell.
2. In the top-right corner of the selected cell, click the menu icon.  Box displays a drop-down menu of formatting actions you can select.
3. In the drop-down menu, click **Distribute columns evenly**.
<Tip>
  To cancel an action:
  * On Windows, press and hold your keyboard's **Ctrl** key and press the **z** key.
  * On Mac, press and hold your keyboard's **Command** key and press the **z** key.
  These key combinations cancel only the immediately preceding action.
</Tip>
