# Creating a Box Note
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "has_image , End User , Box Notes , Article , Product Utilization , Established , Instruction , P1"}} />
It's simple and fast to create a new Box Note.  The process differs slightly, depending on where you are within Box when you create the Note.
**Note**
This article explains how to create a new, blank Box Note.  You can also [create a new Note from a template](/en/box-notes/creating-and-editing-box-notes/using-templates-in-box-notes).
**To create a new Box Note in the default Notes folder**
1. In the lefthand navigation, next to the **Notes** listing, click the plus icon.
  <img src="https://mintcdn.com/product-docs/w-T_6NPwQG7Ze9eT/images/box-notes/notesenhancements-plusiconinleftnav.png?fit=max&auto=format&n=w-T_6NPwQG7Ze9eT&q=85&s=0795154686eab88f7cc4a0395b243e9c" alt="notesenhancements-plusiconinleftnav-png" width="1000" height="448" data-path="images/box-notes/notesenhancements-plusiconinleftnav.png" />
Box automatically stores this note in your default **My Box Notes** folder.
**To create a Note directly into the folder of your choice:**
1. Navigate to the folder you want.
2. From the top navigation, click **New**, and from the list that displays, click **Box Note**.
  <img src="https://mintcdn.com/product-docs/w-T_6NPwQG7Ze9eT/images/box-notes/notesenhancements-newmenuinfolder.png?fit=max&auto=format&n=w-T_6NPwQG7Ze9eT&q=85&s=57ab4109a6de915356804de2b4f287c1" alt="notesenhancements-newmenuinfolder-png" width="1607" height="728" data-path="images/box-notes/notesenhancements-newmenuinfolder.png" />
Box automatically stores your Note in your current folder.
There are two other easy ways to create a new blank Box Note:
* Directly from an existing Box Note.  To do this, open any Box Note, navigate to the top navigation and click **New**.
* Via **[https://app.box.com/notes/create\_note](https://app.box.com/notes/create_note)**.  Save this URl as a shortcut or bookmark in your browser.  Then click on it to open a new, blank Box Note.
In all of the above cases, you can title the note by clicking the header bar (Default title: **Add a Title**)  and type in your own title. When you begin typing, Box also automatically saves your changes.
**Note:** You can't use forward slashes and backslashes in the title of your Box Note. Box will not save titles containing these characters.
More on [creating Box Notes from templates](/en/box-notes/creating-and-editing-box-notes/using-templates-in-box-notes).
