# Using the Status-and-Transfers Icon
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "End User , Box Mobile , Article , Product Utilization , Established , Instruction , P2"}} />
When you're
* uploading or downloading a file or folder,
* moving or copying a file or folder, or
* marking for offline access a file or folder,
the status-and-transfers icon at the top of the screen displays the current progress of the action. The status-and-transfers icon also enables you to cancel the action, retry a failed action, or retry an action that returned an error.
  <img src="https://mintcdn.com/product-docs/kvkGVzDUZ2GDsgwd/images/box-mobile/jobsstatus.png?fit=max&auto=format&n=kvkGVzDUZ2GDsgwd&q=85&s=e2c9812e1b200806f9ebd78d394bd7e9" alt="jobsstatus-png" width="493" height="426" data-path="images/box-mobile/jobsstatus.png" />
**To see the detailed status of the action:** tap the status-and-transfers icon.
**To Cancel or Retry the action:**
1. Tap the status-and-transfers icon.  Box displays the status window.
2. Beside the file or folder name, tap the loading icon and select the option you want to perform.
