# Using the Box Notification Center on Mobile
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "has_image , End User , Box Mobile , Article , New , Product Utilization , Instruction"}} />
The Box Notification Center on Mobile displays a summary of notifications sent to you by Box, and by the people you work with. Notifications can include
* @mentions,
* collaboration invitations,
* shared link announcements,
* file annotations,
* task reminders, and
* updates on collaborator activities.
If you [turn off auto-acceptance of incoming invitations](/en/box-fundamentals/for-users/user-login-and-settings/manage-account-settings#collaborating-on-content), the Box Notification Center on Mobile enables you to accept or decline collaboration invitations. The Notification Center also displays invitations to enroll in two-factor authentication (2FA), accept Terms of Service, or set a strong password to access shared content.
With support on Android and iOS, the Box Notification Center enables you to review your workflow notifications on the go, so you can quickly and efficiently stay up-to-date on the work you're involved in.
  * Support on **Android** is coming soon for
    * task notifications,
    * accepting invitations to enroll in two-factor authentication (2FA),
    * accepting Terms of Service, and
    * accepting invitations to set a strong password.
  * The Notification Center does not provide expiration notifications, but Box does send these notifications to you through email.
  * The Notification Center does not support filtering of notifications.
## Reviewing your notifications
When you receive a notification, Box displays a badge next to the Notification Center in your Inbox showing how many unread notifications you have.
  <img src="https://mintcdn.com/product-docs/kvkGVzDUZ2GDsgwd/images/box-mobile/mobile-notificationcenter-highlight-77111.png?fit=max&auto=format&n=kvkGVzDUZ2GDsgwd&q=85&s=f5be6278492d313f162bbe4d2777950e" alt="mobile-notificationcenter-highlight-77111-png" width="378" height="762" data-path="images/box-mobile/mobile-notificationcenter-highlight-77111.png" />
**To review your notifications:**
1. In the footer bar, tap **Inbox**.
2. In the top of the Inbox window, a badge next to **Notifications** displays how many unread notifications you have. Tap **Notifications**.
3. Box displays the list of your notifications. Unread notifications have a blue background, and read notifications have a white background.
**To accept or decline an invitation:**
2. At the top of the Inbox window, tap **Notifications**.
3. Below the invitation, tap **View Details**.
4. In the invitation, tap **Accept**, or tap **Decline**.
