# Viewing Annotated Files with Box for iOS
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "End User , Overview , Box Mobile , Annotations , Mobile annotations , Article , Product Utilization , Established , Mobile - iOS"}} />
Box annotations accelerates the review and decision-making process by unifying feedback across desktop, Web, and mobile Box apps.  Using only your iOS device, you can:
* [Create and view freeform hand-drawn annotations](/en/box-mobile/box-for-ios/drawing-annotations-on-ipads-and-iphones) in Box Preview, and share those annotations with others.
* Securely view annotations across files, documents, images, and video files without having to open the application in which the content was created.
* Receive immediate notification of new annotations or feedback when someone mentions you in an annotation comment.
* View comments in your Box Notification Center.
Here’s how to work with Box Annotations on your iOS device:
When someone uses the Box Web app to annotate a document, Box records details in the **File Activity** pane, including the commenter’s name, the time of the comment, and the page number of the annotated section.   (The **File Activity** pane displays on the right side on iPads, and via the button on iPhones.)  When they’re done they can share the annotated document with you via a shared link, or directly notify you by using the @ command and your user name within a comment.  You receive an email with a link to the document, plus an alert on your home screen.
  <img src="https://mintcdn.com/product-docs/kvkGVzDUZ2GDsgwd/images/box-mobile/notificationonhomescreen.png?fit=max&auto=format&n=kvkGVzDUZ2GDsgwd&q=85&s=b5b98e71b2d26a68c2e2b886632b694a" alt="notificationonhomescreen-png" width="375" height="812" data-path="images/box-mobile/notificationonhomescreen.png" />
Tap the alert (or the emailed link), and Box opens the file preview to the annotated area, regardless of where in the document it may be.
  <img src="https://mintcdn.com/product-docs/kvkGVzDUZ2GDsgwd/images/box-mobile/viewannotation.png?fit=max&auto=format&n=kvkGVzDUZ2GDsgwd&q=85&s=ab567977e3ed779475c06064e603072f" alt="viewannotation-png" width="377" height="812" data-path="images/box-mobile/viewannotation.png" />
You can view all existing comments in the **File Activity** pane.
  <img src="https://mintcdn.com/product-docs/miYvheuSw76MH4Yu/images/box-mobile/commentnotificationrevised.png?fit=max&auto=format&n=miYvheuSw76MH4Yu&q=85&s=62dd1344541403f9c64088e721d6e03d" alt="commentnotificationrevised-png" width="371" height="585" data-path="images/box-mobile/commentnotificationrevised.png" />
Tap **Page #** in a comment, and Box immediately displays the page with the corresponding annotation.
You can also view an annotated document on your iOS device by navigating directly to the file you want and then opening it in Box Preview.
**Note**
Update to the latest version of the Box app if you receive an alert indicating some comments are not visible.
For more information, including a list of file types you can annotate in Box, please see details on how to [create annotations using the Box Preview app](/en/box-fundamentals/for-users/collaborating/sharing-content-using-box/annotating-documents).
