# Using Collections for iOS
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "End User , Box Mobile , Article , Product Utilization , Established , Mobile - iOS , Instruction"}} />
When you're on the go, Box Collections for iOS enables you to create and name private collections of content in your Box account, where you can organize files and folders that you own or share.  And although the content may be shared, your collections are not shared and are visible only to you.
  <img src="https://mintcdn.com/product-docs/miYvheuSw76MH4Yu/images/box-mobile/collections-ios.png?fit=max&auto=format&n=miYvheuSw76MH4Yu&q=85&s=70704539716fb33dea3f742cfe98428d" alt="collections-ios-png" width="320" height="670" data-path="images/box-mobile/collections-ios.png" />
Using Box Collections you can
* intuitively organize your Box content into logical groupings of your choice,
* name these groupings to provide clear and meaningful context, and
* quickly find the content you need right now.
**To create a collection:**
1. In the top of the screen, tap **+**.  Box displays the **Create a Collection** window.
2. In the text field type the name of the collection.
3. Tap **Create**.
  <img src="https://mintcdn.com/product-docs/miYvheuSw76MH4Yu/images/box-mobile/collections-create-ios.png?fit=max&auto=format&n=miYvheuSw76MH4Yu&q=85&s=76f930a40249e0fe56a5aa9b502587e2" alt="collections-create-ios-png" width="319" height="671" data-path="images/box-mobile/collections-create-ios.png" />
**Note**
* After you add files and folders to a collection, the name of the collection appears next to the names of these files and folders throughout your Box account.
* Your **Favorites** category is now a collection.
Box lists all your collections in the **My Collections** tab.
**To view a collection:** tap the name of a collection.  Box displays the names of the folders and files in the collection.
**To add a new item to a collection:**
1. Tap the item you want to add.  Box displays the preview screen.
2. In the bottom menu of the preview screen, tap **Collections**.
3. Tap the name of the collection to which you want to add the file.
