# Collaborate Using Box for Android
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "has_image , End User , Box Mobile , Article , Product Utilization , Established , Instruction , Mobile - Android , P6"}} />
Add collaborators or send a shared link through the Box for Android app, just as you would on your desktop.
### Sharing
To send a shared link to an item in Box:
1. Locate the file or folder you'd like to share
2. Tap the **ellipsis** (**...**) to the right of the item name to open the **More Options** menu.
3. Tap **Share**, then tap the **Share link enabled** slider to generate a shared link.
  <img src="https://mintcdn.com/product-docs/miYvheuSw76MH4Yu/images/box-mobile/box-for-android-10.png?fit=max&auto=format&n=miYvheuSw76MH4Yu&q=85&s=2b8d3e86d5908f10050492f88cc0bae7" alt="box-for-android-10" width="999" height="888" data-path="images/box-mobile/box-for-android-10.png" />
You can copy the link to the clipboard and paste it later, or send the link directly using the messaging/email app of your choice.
### Access Limits and Restrictions
You can set access limits, restrict actions, and set an expiration date for your shared link before sending it out. Tap **Edit Link Access** to modify shared link settings.
  <img src="https://mintcdn.com/product-docs/miYvheuSw76MH4Yu/images/box-mobile/box-for-android-11.png?fit=max&auto=format&n=miYvheuSw76MH4Yu&q=85&s=829f45eb5eab2f6648ed41c2f9cd2777" alt="box-for-android-11" width="999" height="888" data-path="images/box-mobile/box-for-android-11.png" />
**Link Access:** Secure this link so only a select group of people can access your content or leave it open for public access
* *People with the link:* Anyone who has the link can view your content, whether they're logged in or not. We recommend one of the other access levels for files or folders you'd like to keep secure.
* *People in your Company:* Allows anyone with a Box account at your company to see your content. Users will need to be logged in to see the file or folder linked and you will usually be able to see which specific users in your company have viewed your files.
* *People in this folder:* Access is limited only to users you’ve invited to your file or folder as Collaborators. You can invite or remove Collaborators to expand or limit the list of users who can view your files.
**Downloads allowed:** If this option is enabled, users accessing your file or folder from the link can also download your content. Turn this off if you'd like to create a view-only link.
**Require Password:** If this option is enabled, users accessing your file or folder via this shared link will be prompted to enter a password before they can view the item. You can set the password and modify it at any time.
**Expire Link:** The link will be deleted on the date you set in this field. Leave this option inactive if you don't want the link to expire. If you set an expiration date, users will not be able to access your file or folder from the link after that date.
### Add and Manage Folder Collaborators
Box collaborators have different [access levels](/en/box-fundamentals/for-users/collaborating/collaborating-by-inviting-others/understanding-collaborator-permission-levels). Each access level has different permissions for different features when using Box.
### Add Collaborators
1. Locate the file or folder into which you'd like to add collaborators.
2. Tap the **ellipsis** (**...**) to the right of the file or folder name to open the **More Options** menu.
   * Alternatively, you can open a folder, tap the ellipsis in the top-right corner, and select **Folder Actions**.
3. Tap **Share**, then tap **Add Collaborators**
4. Start typing the name or email of a person in your contacts and the closest matches will appear below. Select the required name/email.
5. Assign the required [access level.](/en/box-fundamentals/for-users/collaborating/collaborating-by-inviting-others/understanding-collaborator-permission-levels)
6. Tap the **Send** icon in the top-left corner to send collaboration invites.
**Note**
When inviting collaborators to a single file, the only available access level is **Editor**. Users can change this access level to **Viewer** from the **Manage Collaborators** page. These are the only access levels available for collaborators on a single file.
### View and Manage Collaborators
1. Locate the file or folder in which you'd like to manage collaborators.
3. Tap **Share**, then tap **Manage Collaborators**.
4. You will see a list of all collaborators who have access to the file or folder. Collaborators are displayed prioritized by access level.
5. Tap a collaborator to modify their access level, or remove them from the file or folder.
