# Android Annotations: Highlight region and highlight text
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "End User , Overview , Collaboration , Box Mobile , Instructions , Article , Product Utilization , Established , Mobile - Android"}} />
Today, the feedback and review process is overly complex and inefficient.
* Feedback is dispersed across emails and other chat tools
* Comments are not in-line, so it's unclear what content a comment is referring to
* Reviewers need to open the app the file was created in to leave comments
With annotations on Android, users can now review and leave comments directly within file preview.
**Highlight Region**
If users need to indicate a certain part of a document for editing, they can make use of the highlight region annotation. This allows users to draw a Box around a section of the document, and add a comment. Optionally, they can also @mention another collaborator on the file to draw their attention to the annotation.
To do this:
* Open the file in **Preview** on an Android phone.
* Tap on the **annotations icon** at the bottom of the preview screen to open the annotations toolbar. You will see a set of tools appear.
* Next, select the **highlight region tool.**
* Tap and drag anywhere on the file itself to draw a box.
* After lifting your finger, the comment field will appear by default. Add a comment and tap “**Save**”.
**Highlight Text**
Users will also now be able to highlight and leave text comments on any part of a document or an image and @ mentioned collaborators will receive an email notification and a push notification on their mobile device.
To do this:
* Next, select the **highlight text tool**.
* Tap and drag on a section of text within the file itself to highlight it.
