# Working with the Box Hubs Builder
    display: "inline-block",
    verticalAlign: "middle",
    height: height,
    width: "auto",
    margin: "0"
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "End User , Article , Product Utilization , Tech Pubs , Established , Mobile - iOS , Instruction , Mobile - Android , Desktop - Windows , Desktop - iOS , Box Hubs , P2"}} />
The Box Hubs builder provides an intuitive interface for organizing your Hub content. The builder uses the same interaction model as other Box tools, making it easy to learn and use.
## Before you begin
To organize a Hub, you must have co-owner or editor permissions. For details, see [Box Hubs Permissions](/en/box-hubs/box-hubs-for-admins/box-hubs-permissions).
## Edit your Hub
To open a Hub in edit mode:
1. Go to the Hubs gallery.
2. Select the Hub you want to edit.
3. In the upper-right corner, select **Edit**.
The **Add Block** panel displays on the right side. The panel lists all available content block types you can add to your Hub.
  <img src="https://mintcdn.com/product-docs/5crRvK1JJWJHGVGu/images/box-hubs/hub-builder.png?fit=max&auto=format&n=5crRvK1JJWJHGVGu&q=85&s=6c868d248f30129aceee6b1a8408e35d" alt="Box Hubs builder with the Add Block panel open on the right side of a Hub page" width="2454" height="1298" data-path="images/box-hubs/hub-builder.png" />
<Tip>
  To move blocks, format text, add a page, or save your Hub without the mouse, press **Alt/Option** + **Shift** + **/** to open the **Keyboard Shortcuts** panel. For the full list, see [Using keyboard shortcuts in Box Hubs](/en/box-hubs/using-box-hubs/using-keyboard-shortcuts-in-box-hubs).
</Tip>
## Logo and header alignment
You can center-align the logo in the Hub builder. When you center-align the logo, the Hub name and description are also center-aligned.
## Content blocks
Content blocks are the building blocks of your Hub. Each block type serves a different purpose:
| Block type | Description |
| Files and Folders | Add content from your Box account. |
| Section Header | Create an organizational section with a title (up to 100 characters). |
| Paragraph | Add text content (up to 5000 characters). |
| Image | Add an image inline, with aspect ratio, cropping, and full-screen viewing. |
| Link Cards | Add a block that displays a set of cards, each linking to a configurable destination. |
| Call Out | Highlight important information in a new call out window (up to 5000 characters). |
| Link Preview | Embed interactive content directly in your Hub. |
| Divider | Add a visual separator between content. |
### Add a block
Use either method to add a block:
**Method 1: Select to add**
1. In the **Add Block** panel, select the block type.
2. The block displays at the end of the page.
**Method 2: Drag to add**
1. In the **Add Block** panel, drag the block type onto the page.
2. Drop it in the desired location.
### Manage blocks
To manage a block:
1. Select the block on the canvas.
2. The context toolbar displays with available options:
   * Move up or down
   * Move to a Different Page
   * Duplicate
   * Trash
   * Add Items (for **Files and Folders** blocks)
   * Display as grid or list (for **Files and Folders** blocks)
   * Formatting toolbar (for **Paragraph** and **Call Out** blocks)
To reposition a block, select it and drag it to the new location.
  In **Files and Folders** blocks, individual files become draggable only after you select the block. This prevents accidental movement.
  * **List view**: Drag and drop files or folders to reorder them.
  * **Grid view**: Select a file or folder, select the ellipsis (...) at the bottom of the card, and then select the **Move Left** or **Move Right** arrow.
### Delete a block
1. Select the block.
2. On the context toolbar, select **Trash**.
<h3 id="link-cards">
  Link Cards
</h3>
The **Link Cards** block displays a row of customizable cards that link to Hub pages, Box content, or external URLs. When you add the block, three empty cards display by default.
To configure a card, select it, add a link, and edit the title, description, or background image. When you add a link, the card pulls the title, description, and image from the destination if those details are available. Cards that link outside your enterprise display an external link icon and open in a new tab.
To manage cards within the block:
* Select **Add Card** to add a card.
* Select **Trash** on the card toolbar to remove a card.
* Use the arrows on the card toolbar to reorder cards.
From the block's context toolbar, switch between **Left Align** (default) and **Fill** (full-width) layouts.
  * A **Link Cards** block must contain at least one card. When you remove the last card, the entire block is deleted from the page.
  * If you save the Hub with a card that has no link added, that card doesn't display when viewers open the Hub.
<Warning>
  Hub access does not automatically grant viewers access to the destination of a card. If a viewer does not have access, they see the standard error state on the destination page.
</Warning>
## Images
The **Image** block adds a graphic directly to your Hub layout, so you can include visuals without relying on a link preview. Each image displays inline and adapts to the layout, keeping its aspect ratio across desktop, tablet, and mobile screens.
### Add an image
1. In the **Add Block** panel, select **Image** or drag it onto the page.
2. In the Image block placeholder, choose one of these sources:
   * **Upload from computer** — select an image file, such as a JPG, PNG, or GIF, from your device.
   * **Upload from Box** — select an image already stored in Box using the content picker. You need at least Viewer access to the file.
The image uploads and displays inline within the block.
If you add an unsupported file type or a file that exceeds the maximum size, the image isn't added and an error message explains why. For an upload that fails due to a connection or server error, select **Retry**.
### Set the aspect ratio and crop
After you add an image, it displays at its original size. To frame it, select an aspect ratio from the image toolbar:
* **Original** — keeps the image's original proportions. This is the default.
* **Portrait** — 3:4
* **Square** — 1:1
* **Wide** — 16:9
* **Extra Wide** — 21:9
When you select an aspect ratio other than **Original**, the image is cropped to that ratio from the center, and the toolbar displays an **Adjust** button. To reframe the image within the ratio, select **Adjust**, drag the slider to change how the image fills the frame, and then select the checkmark to apply. The aspect ratio stays fixed as you adjust.
If you change the aspect ratio or replace the image, the crop resets to the center so you can adjust it again. To swap in a different image, select **Change Image** on the toolbar.
### Resize an image
To resize an Image block, drag its top or bottom edge up or down. As you drag, the block moves through the preset aspect ratios — Portrait, Square, Wide, and Extra Wide — and snaps to the nearest one when you release. This is an alternative to selecting a ratio from the toolbar.
### View an image full screen
When viewing a Hub, select an image to open it in full-screen mode.
## Sections
Sections help you organize related content by creating visual separators on your page. Each section title marks the beginning of a new section.
### Create a section
1. In the **Add Block** panel, select **Section Title** or drag it onto the page.
2. Enter a section title (up to 100 characters).
3. Add content blocks to your section.
When you add a section title, an outline is created automatically in the Hub navigation. This makes browsing easier for viewers.
### Reorder sections
1. Select the section title.
2. In the context toolbar, select **Move Up** or **Move Down**.
3. Move the section to the desired position.
### Rename a section
2. Enter the new title.
### Delete a section
1. Select the section.
2. In the context toolbar, select **Trash**.
## Pages
Pages provide another level of organization in your Hub. You can create multiple pages and nest them to build a clear hierarchy.
### Display pages horizontally or vertically
As an editor, you can display your Hub's pages in one of two layouts. Choose the one that fits your Hub:
| Layout | Pages display as | Best for |
| Vertical (default) | An outline along the side | Internal Hubs |
| Horizontal | A tab bar across the top | External-facing or content-heavy Hubs with several top-level pages |
Switching between layouts changes only how viewers navigate. Your page content and hierarchy stay the same.
To switch, open your Hub in edit mode and select the display icon next to the page list. Its tooltip displays the layout it switches to:
* **Display pages horizontally** (<InlineImage src="/images/box-hubs/display-pages-horizontally-icon.png" alt="Display pages horizontally icon" />) — moves the pages into a tab bar across the top.
* **Display pages vertically** (<InlineImage src="/images/box-hubs/display-pages-vertically-icon.png" alt="Display pages vertically icon" />) — returns the pages to the outline along the side.
In the vertical layout:
* Nested pages display indented under their parent page.
* To reorder pages, drag a page up or down.
* To open a page, select it in the outline.
In the horizontal layout:
* Nested pages display under their parent tab.
* To reorder pages, drag a tab left or right.
* To open a page, select its tab.
### Add a page
1. In the Hub outline panel (when pages display vertically) or tab bar (when pages display horizontally), select **Add Page** (+).
2. Replace the default title with your page name.
The default title format is "Untitled Page \[yyyy-mm-dd hh:mm:ss]."
### Add a nested page
Nested pages (subpages) display under a parent page in the hierarchy.
1. In the Hub outline panel (when pages display vertically) or tab bar (when pages display horizontally), hover over the parent page.
2. Select the ellipsis (...) to open the page options.
3. Select **Add Nested Page**.
4. Enter a title for the nested page.
### Duplicate a page
1. In the Hub outline panel (when pages display vertically) or tab bar (when pages display horizontally), hover over the page.
3. Select **Duplicate Page**.
### Change page hierarchy
You can reorganize your pages at any time:
* **Reorder pages**: In the Hub outline, drag a page up or down. In the tab bar, drag a tab left or right.
* **Create nested pages**: Drag a page onto another page to make it a subpage.
* **Promote nested pages**: Drag a subpage into the main page area to make it a top-level page.
  Your home page is always the highest page in the hierarchy and can't be moved.
### Delete a page
3. Select **Delete Page**.
4. In the confirmation dialog, select **Delete**.
<Warning>
  When you delete a page, all content within it is deleted, including blocks and nested pages. This action can't be reversed.
</Warning>
## Notify collaborators of changes
After you make changes to your Hub, you can notify all collaborators through email.
### Send a change notification
1. Make your changes to the Hub.
2. In the upper-right corner, select **Save** > **Save & Notify Collaborators**.
3. In the notification dialog, enter a message describing your changes.
4. Select **Save & Notify**.
All Hub collaborators receive an email notification with your custom message and a link to open the Hub. As the sender, you do not receive this email notification.
### Save without notifying
If you don't want to notify collaborators:
2. In the upper-right corner, select **Save**.
Your changes are saved, but collaborators don't receive an email notification.
