# Viewing hub insights
Hub Insights gives hub owners and co-owners a view of how their hub is being used, right from the hub itself. Use it to see whether a hub is reaching its audience, who is engaging with it, and when it might need a refresh.
> [!NOTE]
> Hub Insights is available in the Box web app to hub owners and co-owners. It requires no admin configuration.
## Opening Hub Insights
To open Hub Insights:
1. Open the hub.
2. In the hub header, select **More Options** (**⋯**) > **Hub Insights**.
The **Hub Insights** dialog opens with three panels: **Hub Activity Summary**, **Collaborators**, and **Activity Feed**.
![Hub Insights dialog showing the Hub Activity Summary chart of views and edits, the Collaborators chart split by internal and external type, and the Activity Feed list with a Load more option](https://mintcdn.com/product-docs/JpgJjKMjv3VUCwyL/images/box-hubs/hub-insights.png?fit=max\&auto=format\&n=JpgJjKMjv3VUCwyL\&q=85\&s=c926775dc96fd211529290d02d49afed)
## Hub activity summary
**Hub Activity Summary** displays a chart of hub views and edits over time. You can display activity for the last 30, 60, or 90 days, or select a custom date range within the past year.
To display only views or only edits, clear the **Views** or **Edits** checkbox below the chart.
## Collaborators
**Collaborators** displays how many people and groups the hub is shared with, split between internal and external collaborators.
To display only one type of collaborator, clear the **Internal** or **External** checkbox next to the chart.
## Activity feed
**Activity Feed** lists who viewed or edited the hub and when. This includes views from people who open the hub through a shared link without signing in to Box.
To display older activity, select **Load more** at the bottom of the feed.
