# Searching Box Hubs
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "End User , Article , Product Utilization , Tech Pubs , Established , Mobile - iOS , Instruction , Mobile - Android , Desktop - Windows , Desktop - iOS , Box Hubs , P3"}} />
Search Box Hubs in the Hubs gallery or inside a Hub. Use filters to make your search more detailed.
  **Note**
  In the edit mode, click the **Select Metadata** to add filters that allow your users to search for content faster.
## Hubs gallery
To search for a specific Hub, go to the Hubs gallery and enter the Hub name in the search bar.
You can also filter and sort the Hubs.
### Filter options:
* **All**
* **View Access**
* **Edit Access**
### Sort options:
* **Recently updated**
* **Most viewed**
  **Note**
  Search indexes only the first 200 characters of a Hub description. This is the same text that appears on the Hub card in the Hubs gallery. Content beyond the first 200 characters isn’t indexed and won’t appear in search results.
## Inside a Hub
Open the Hub and enter a keyword in the Hub search bar. You can also click the **Filters** icon in the search bar and use filters to make your search results more specific.
You can filter the content by:
* **File Type** (multi-choice)
  * Document
  * PDF
  * Presentation
  * Spreadsheet
  * Image
  * Video
  * Audio
  * Drawing
  * 3D
  * Box Note
  * Box Canvas
* **Date Updated** (multi-choice)
  * Any time
  * Last day
  * Last week
  * Last month
  * Last year
  * Custom range (you need to specify the date range)
* **Owners** (type in the name of the owner)
* **Metadata**
On the search results page, you can sort the files by their relevance and update date (newest or oldest).
  **Note**
  You can also use the global search, the Hub files are included in the search results.
### Metadata
To add metadata to your Hub search, click the **Select Metadata** button.
Select the metadata filter from the dropdown list under the **Metadata** section, for example **Background Check Alert**.
