# Box Hubs Reports
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "Overview , Admin , Article , Established , Desktop - Windows , Desktop - iOS , Box Hubs , P2"}} />
Box Hubs admin reports display the details of the Hubs in your enterprise. Reports are exported as .csv files to your **Box Reports** folder when complete.
  **Note**
  To [run](/en/box-admin-tools/reporting-and-insights/running-reports) a report, you need to be an admin or have the requisite [co-admin permissions.](/en/box-admin-tools/reporting-and-insights/co-admin-permissions-required-to-run-reports)
Apart from running a report, you can save its configuration, schedule it, and subscribe specific users to it.
### Box Hubs report details
* File format: comma-separated value (.csv) file
* Filename format: `hubs_run_on_YYYY-MM-DD-HH-MM-SS_[A|P].csv`
## Box Hubs report columns
In the generated Box Hubs report you can find the following columns:
<h3 id="hub-id">
  Hub ID
</h3>
A unique identifier for the hub.
<h3 id="hub-name">
  Hub Name
</h3>
The name given to the Hub.
<h3 id="hub-description">
  Hub Description
</h3>
Any description entered when creating or editing the Hub. Will be blank if no description has been added.
<h3 id="creator-id">
  Creator ID
</h3>
A unique identifier ascribed to the person who created the Hub.
<h3 id="creators-user-name">
  Creator's User Name
</h3>
The username of the individual who created the Hub.
<h3 id="creators-email">
  Creator's Email
</h3>
The value in the Email field in User Account Details of the individual who created the Hub.
<h3 id="created-date">
  Created Date
</h3>
The date that the Hub was created.
<h3 id="number-of-total-views">
  Number Of Total Views
</h3>
The total number of times the Hub has been viewed, including repeat views.
<h3 id="last-viewed">
  Last Viewed
</h3>
The date that the Hub was last viewed by any user.
<h3 id="last-updated">
  Last Updated
</h3>
The date that the Hub was last updated by any user.
