# Box Hubs Permissions
<div className="article_labels_list" style={{display: 'none'}} dangerouslySetInnerHTML={{__html: "Overview , Admin , Article , New , Box Hubs , P2"}} />
There are four levels of permissions in Box Hubs: Admin, Co-Owner, Editor, and Viewer.
* Admin can only enable Box Hubs for specific users/user groups.
* Co-Owner has the broadest permissions.
* Editor has the same permissions as a Co-Owner, except for creating and deleting a Hub, and managing Hub settings.
* Viewer cannot make any changes to the Hubs they are invited to.
Below table lists all actions each of them can perform in Hubs.
|        | <strong>Admin</strong> | <strong>Co-Owner</strong> | <strong>Editor</strong> | <strong>Viewer</strong> |
| <strong>Enable Hubs for certain users or groups of users</strong> | ✓                      |                           |                         |                         |
| <strong>See Hubs in gallery</strong>                              |                        | ✓                         | ✓                       | ✓                       |
| <strong>Create a Hub</strong>                                     |                        | ✓                         |                         |                         |
| <strong>Delete a Hub</strong>                                     |                        | ✓                         |                         |                         |
| <strong>See Hub details page</strong>                             |                        | ✓                         | ✓                       | ✓                       |
| <strong>Upload background and logo</strong>                       |                        | ✓                         | ✓                       |                         |
| <strong>Manage Hub users</strong>\*                               |                        | ✓                         | ✓                       |                         |
| <strong>Manage Hub settings</strong>                              |                        | ✓                         |                         |                         |
| <strong>Add/delete components</strong>                            |                        | ✓                         | ✓                       |                         |
| <strong>Move components</strong>                                  |                        | ✓                         | ✓                       |                         |
| <strong>Save and publish the Hub</strong>                         |                        | ✓                         | ✓                       |                         |
| <strong>View the Hub</strong>                                     |                        | ✓                         | ✓                       | ✓                       |
| <strong>Share the Hub</strong>\*                                  |                        | ✓                         | ✓                       | ✓                       |
| <strong>Copy the Hub</strong>\*                                   |                        | ✓                         | ✓                       | ✓                       |
| <strong>Create shared links</strong>                              |                        | ✓                         | ✓                       |                         |
| <strong>Create embeds</strong>                                    |                        | ✓                         | ✓                       |                         |
\*These settings can be configured.
  **Notes**
  * If you access Box Hubs through a shared link and you have an editor access to some files or folders, you cannot edit them from a Hub level. For more information on shared links, see [Creating Shared Links](/en/box-fundamentals/for-users/collaborating/using-shared-links/creating-shared-links).
  * Granting a user access to a Hub automatically gives them **Viewer** permissions to all files and folders in that Hub. This does not apply to external or Box links embedded in the Hub using **Link Preview** or **Link Cards**.
  * If a folder **Uploader** is invited to a Hub as **Viewer**, the folder **Uploader** permissions to the content change to **Viewer/Uploader**.
